Old 12-07-2009, 06:23 PM   #1
72GREENC10
72GREENC10's Avatar
c notch
i am doing a c notch on my 72 c10 longbed, and i am not looking to buy a kit, i was told that a piece of pipe cut in half would work for a notch, or a square piece of metal with the bottom on it cut out will work, whick would do better?
72GREENC10 is offline   Reply With Quote
Old 12-07-2009, 06:42 PM   #2
lofly'a
lofly'a's Avatar
Re: c notch
i used a piece of 5" pipe split in half. if you plan to tow or haul much, you'll want to box that area round the notch as well.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 12-07-2009, 06:59 PM   #3
72GREENC10
72GREENC10's Avatar
Re: c notch
ok, thx
Old 12-07-2009, 07:10 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: c notch
This is my 77 Cheyenne. Different frame. same principal...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-07-2009, 07:12 PM   #5
72GREENC10
72GREENC10's Avatar
Re: c notch
would i lose strength in the frame, im not towing anything, but i dont want to go over a bump and watch me bed roll away.
Old 12-07-2009, 07:15 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: c notch
If anything this set up will make it stronger.
I have seen it done with the C-notch and no boxing plate. I would be concerned there, but I am prone to overdo things.
Articles-
"Refining Sierra"
Old 12-07-2009, 07:21 PM   #7
72GREENC10
72GREENC10's Avatar
Re: c notch
ok, and what size pipe did you use for the notch?
Old 12-07-2009, 07:59 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: c notch
The notch will only be as "good",... as the welder, that is doing the work.
Plus the frame is not straight in the area that you are c-notching.
Keith
Convert to disc brakes.
Old 12-07-2009, 09:39 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: c notch
I believe this was 6".
Articles-
"Refining Sierra"
Old 12-07-2009, 10:34 PM   #10
kev2809
low n' slo
kev2809's Avatar
Re: c notch
im gonna this same thing but ima go with 8.5" pipe. that way i can use some for the lca's also.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-07-2009, 11:14 PM   #11
MXmaniac
MXmaniac's Avatar
Re: c notch
I'm working on mine right now. I used 4-1/2" OD pipe, 1/4" thick. The ID is 4" so it's a 2" notch.
I would use round over square. Looks cleaner and I just feel like it's stronger since the stress won't be concentrated in any corners. Plus it's less vertical-up welding if you're not comfortable with out-of-position welding.
Here's mine. I finished welding it last night but didn't take any pictures of it welded up. I'm going to box the frame here too.
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 12-08-2009, 12:31 AM   #12
Scottshotrods
Re: c notch
If you are concerned about your frame flex when you have the frame
c-knotch.You can also plate the outside of the frame where the frame
is c-knotch.We do this on alot of trucks that plan on towing trailers or
boats etc.
Justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 12-08-2009, 01:16 AM   #13
72hotrodder
THE TOY STORE
72hotrodder's Avatar
Re: c notch
i had a 72 with a small notch like that for a long time and used it as a tow pic. i notched and boxed like everyone else but i also took a piece of 1x2 quarter in trube and layed it under the top of the frame and plug welded it a few times. made it about 2 foot long, not sure if it really helps alot but always made me feel better
having a badass truck and not driving it is like having a playboy model as a wife and not..... well you know.
72hotrodder is offline   Reply With Quote
Old 12-08-2009, 02:44 PM   #14
72GREENC10
72GREENC10's Avatar
Re: c notch
thanks for the reply's, i am going to probably going to get a pipe as my notch, and plate around the notch for strength
Old 12-08-2009, 04:24 PM   #15
72GREENC10
72GREENC10's Avatar
Re: c notch
does the bed need to be removed to c notch my rear end?
Old 12-08-2009, 08:46 PM   #16
MXmaniac
MXmaniac's Avatar
Re: c notch
I'm sure you can do it with the bed on, it just might be a little more tricky. It's nice to have all the room you need.
Andrew
Old 12-08-2009, 08:55 PM   #17
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: c notch
since I just did mine about a couple months ago here is what I learned..... a piece of 5" pipe will make your notch big enough for the pumpkin to just rub the bottom of the bed floor..also take the bed off you'll need to weld the inside of the C of the frame when you put the notch in
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
