Old 12-08-2009, 09:36 PM   #1
crimespree
crimespree's Avatar
Truck wont go into park
Here is the problem, i went into the store the other night, put my truck into park, paid for my purchase, and when i got out my truck was 10 feet back from where i left it. it had rolled 10 feet without me even knowing it. my column is a little out of whack but you can feel it when you pull the shifter go into each gear position, event though the indicator is always showing reverse. is there a way i can adjust this to where i can park on a hill without fear of destroying someones property, or even worse? please help so i can take my truck out without paranoia.
1970 CST - http://67-72chevytrucks.com/vboard/s...d.php?t=350091
1979 Yamaha xs650 bobber - sold
2008 Harley Nightster
crimespree is offline   Reply With Quote
Old 12-08-2009, 09:42 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Truck wont go into park
Well,
If its a column shift, you can adjust it at the top of the linkage rod where it bolts to the lower outside column, but you need to check also to see if you can get it into park by taking off the linkage and manually putting it into park on the trans, you could have broken the parking pawl inside the trans which will require a tear down to fix......Please ensure you use chock blocks to keep it from rolling if you are doing it yourself...
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 12-08-2009, 10:17 PM   #3
kevmic28
kevmic28's Avatar
Also check at the tranny to see if the connection is worn out. Mine is so my shifter is really loose. Sometimes if I slam my hood it pops into gear. I have a lokar shifter rod to replace it.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 12-08-2009, 10:48 PM   #4
bsm78
Reminds me. When i was in high school i drove my dads 78 F100. i stopped at the store near my house. when i came out i couldnt find the truck. thought someone had stole it. then someone pointed across the road and it had crossed the busy highway and backed into my neighbors fence. Funny now looking back.
bsm78 is offline   Reply With Quote
Old 12-09-2009, 01:15 AM   #5
lofly'a
lofly'a's Avatar
if the parking pawl is broken, you only need to drop the transmission pan to repair/replace it. teardown is not necessary, but it seems from your post that all you need is to adjust the linkage.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 12-09-2009, 01:23 AM   #6
pat 70/71
pat 70/71's Avatar
I had that happen to me. went to my girl friends house . hopped out of my 70 chevy truck , (1977) three on the tree/ V-8. Came out 1- hour later my truck was gone! guy down the street asked are you missing something? (My truck had rolled 1/4 mile down the street} and didn't hit anything! wow ! I was nineteen years old , racing motorcycles& chasing my now wife Barbara around ,GOOD TIMES INDEED!! Thanks for the memories , ...Pat
pat 70/71 is offline   Reply With Quote
Old 12-09-2009, 11:30 AM   #7
69GMCLonghorn
69GMCLonghorn's Avatar
Here's a side note to prevent future problems: The parking pawl is really just designed as more of a security devise and not to actually hold the weight of the vehicle. The "proper" way I've been told to park an auto trans vehicle is to put it in neutral, set the E-brake, take your foot off the brake pedal and let it settle on the E-brake. THEN put it in park. This way the tension is on the brakes and not the trans.
Now, how many goof balls like me actually do this?? Probably about 2-3 on a good day. It's overkill, but it can't hurt!
69GMCLonghorn is offline   Reply With Quote
Old 12-09-2009, 12:34 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Another thing you might try is to pull the shift lever back towards you to shift it into park. I bought a truck a while back that would not shift into park. It was because the shift tube was crusty inside the column. I pulled the steering wheel off and squirted PB Blaster down around the tube (inside and out) and sprayed it good down at the bottom by the shift levers, worked the shift lever back and forth, up and down, and every other way I could think of and it loosened up and has worked fine ever since. This condition is amplified by cold temperatures...
LockDoc
Leon
Old 12-09-2009, 07:59 PM   #9
crimespree
crimespree's Avatar
this is my parking habit: arrive at destination, pull the shifter towards me, pull it into park and push the handle back towards the dash - and sometimes it will roll back and catch, and some times it will catch and then seems to bounce out of park. now i park at the closest flat area and do the same steps. i love that truck too much to risk the rolling away and end up having to park 2 or 3 blocks from where im going. i will look into adjusting the linkage when i get back home in a few days. thanks for the advice!
Old 12-09-2009, 10:02 PM   #10
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
This thread makes me love my granny low even more!
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 12-10-2009, 11:42 AM   #11
69GMCLonghorn
AMEN to that, brother!! Every truck I've owned since I was 16 has had a granny gear! I love it!
Old 12-10-2009, 11:07 PM   #12
unclewatts
unclewatts's Avatar
Especially when you want to pull an old tree stump out of the ground!
Old 12-10-2009, 11:27 PM   #13
Wideopenracing15
Wideopenracing15's Avatar
Wait, you can pull the shifter towards you like newer cars?
Wideopenracing15 is offline   Reply With Quote
Old 12-11-2009, 12:00 PM   #14
69GMCLonghorn
Pros of a stick shift over an automatic
1) Trans cooler? Trans cooler lines? What are those?
3) Trans filter? What's that?
4) A shift kit? What's that?
5) Trans overheating? Why? How?
6) Maintenance? Yeah, I change the fluid every 200,000 miles without fail.
7) It's in the gear I want, when I want it there, every time!
8) I have never had a problem with the parking pawl on my trans...
Ok, I'm done being a wise-a** for the day.
Old 12-12-2009, 08:43 PM   #15
crimespree
crimespree's Avatar
yeah... is that not good?
Old 12-12-2009, 09:13 PM   #16
Wideopenracing15
I don't know mine doesn't.
