![]() Join Date: Dec 2009
67 Disc Conversion (I have a complete 84 Rolling Chassis)
First time to post on a forum so hope I do this right. I have a 1967 Chevy LWB that I am wanting to switch over to disc brakes (We are doing a frame up on the truck). I also have a 1984 rolling chassis for a donor truck. Is it possible to just switch the cross member and all from the 2 trucks? Has anyone done this? If so what are the things that I should be prepared to do? (Do I have to pull the motor. Things like that) I would also like to drop the front of the truck 2 inches. Do I need to go ahead and buy drop spindles or can I do this by cutting a coil from the spring.
Any help and feed back would be great. Also how do I create a signature line that has all the projects going? Thanks, Last edited by Original67; 12-09-2009 at 06:00 PM. Reason: Added Signature |
Re: 67 Disc Conversion (I have a complete 84 Rolling Chassis)
Welcome! You are in the right place. There is so much good info on this forum and everyone is very helpful. I have not done it personally but yes your donor truck should be perfect. The cross member will swap right over to your 67. Try a search and you will find what you need or the gurus will come in and help you out. Oh yeah we need some pics please.
1967 SWB Small Window LS1/4l60e-Galaxy Black Project "401 Que"2002 Trans Am WS6 Heads/Cam/LPP LT'S/Borla w/Electric Cut out- Black w/ gray stripes 2007 Big Bear Sled Chopper 9 1/2ft. long 300mm Rear tire-Black with Metallic Gray Ghost flames ![]() "Once you black you never go back!"
I am a Referee of life.
The whole crossmember swaps over.Make sure to get the booster and MC and proportioning/residual valve from the donor.There is a hole or two per side that needs either reaming or drilled.There should be a write up in the FAQ's section (trucks).Should also be a write up on pic posting,and most other posting questions in the FAQ's (site related)Make sure to read and use the one on pics(we's pic hoe's here).
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
BTW my 67 has power brakes currently so will I need the different valve and MC? (I ask as I forgot to get the valve and it was only the chassis nothing else. Also I did not cut the leaf spring mounds from the chassis (again was not thinking
) so what do you all suggest.Also the truck has the upgraded rear end (Stabilizer bar and overloads from the factory) is it possible to do a rear axle swap to a 5 lug to match the front. Recommendations. Last edited by Original67; 12-10-2009 at 11:26 AM. Reason: For Sale |
Happy to be here
![]() Join Date: Mar 2000
Welcome to the forum Original67. Thanks for sharing your build with us. Please note that you must be a subscribing member to offer items "For Sale" or trade....
Its always something!
You can use a rearend out of a 71/72 or have your 67 axles redrilled to the 5 lug pattern
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed ![]() Member of the patina club |
then perhaps you should consider a therapy group instead of this tech forum.....
LOL.....working on trucks is therapy (when everything goes right)...... |
Okay let me make sure that I understand correctly. 71/72 1/2ton trucks are 5 lug with coils right? or did they come with both? Since I have a coil truck already this will bolt right into the existing location correct. If this is the case what would be a fair price for a rear end in the OKC area do you guys think. Or would a swap for an 84 5 lug leaf be fair? I want to make sure that I do this right the first time and not screw it up as it is the boys truck and he has the budget of a 15 year old..
yea right. Sorry for all the questions. I have always worked on 4x4 and never found the need for an axel swap. |
Most chevy trucks came with coils. the 71/72 rearend is a direct replacement for your 67 6lug rear
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
You can buy a complete Disk brake conversion and remain 6 lug. Then you do not have to change the crossmember. When you buy the disk brake conversion, specify 2 1/2" lowering spindles and you wont have to do anything with your springs. You will however still have to deal with the master cylender and proportioning valve. There are a couple of ways to do that. One is just install an adjustible proportiong valve somewhere between your exusting proportioning valve and the rear brakes, and the other is to buy a mastercylinder/booster set up for disk front brakes along with a non adjustible proportiong valve and bracket. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 12-14-2009 at 04:48 PM. |
Since you have already pulled the complete cradle from the 83, I would use it. You gain a few things with the 83 over just converting to discs. The later A-arms have rubber bushings, better ride, better steering. Parts are cheaper to replace and MUCH easier to find locally. Remember to swap the entire cradle,drag link, and tie rods. If you already have a booster, just get a 71-72 MC from NAPA or your favorite box store. The proportioning valve can be found in any junk yard or Master Power Brakes. http://www.mpbrakes.com/
Go to MPB site even if you don't want their prop valve. They are full of information. You can also buy 6 lug rotors from McGaughys if you want to stay with 6 lugs. Some of the board vendors carry McGaughys. Lowering spindles and/or springs can be had from most of the board vendors too. Just some thoughts from someone who has been there, done that, got grease on the T shirt.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 Last edited by ERASER5; 12-14-2009 at 05:38 PM. |
Okay maybe I am having a blonde moment or even just a
moment. So hear it goes anyway. Can I buy 6 lug rotors to fit an 84 spindle. I have to replace the rotors calipers hoses anyway so if I can do this it will keep me from having to do something in the rear. If so what year fits? Will the bearings need to be 84 or will they need to be for whatever the rotors are for. Please tell me this will work. Oh please Oh please Oh Please.
| Bookmarks |
| Tags |
| disc brakes, drop, swap |
| Thread Tools | |
| Display Modes | |
