Old 12-10-2009, 06:32 PM   #26
smokedat
smokedat's Avatar
Re: LS1 Swap to a 73 cheyenne
deleted double post
smokedat is offline   Reply With Quote
Old 12-10-2009, 06:36 PM   #27
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
yeah there 799 virtually the same as 243 casting. The exhaust port is D-shape wich come on the LS6
Old 12-10-2009, 06:39 PM   #28
smokedat
smokedat's Avatar
Belt, A/C compressor, and power steering pulley are off. Waiting on the A/C relocator pwr steering pulley and belt.
Old 12-10-2009, 06:46 PM   #29
smokedat
smokedat's Avatar
There is no difference between the two heads. The numbers tell what original mold the casting came from. 243 mold was done at GM Research, the 799 mold is used by other vendors. The same vendor will have 243 and 799 molds. The numbers are just a GM system for when the mold was made. If a head had a problem it helps them track down where the problem started. The only difference between the heads is production variance.
Old 12-10-2009, 06:50 PM   #30
smokedat
smokedat's Avatar
menace121978 the radiator was 700 shipped 645 with trans cooler w/o 595, as for the clean up I used regular break cleaner works good.
Old 12-10-2009, 07:34 PM   #31
mcbassin
Still Learning
mcbassin's Avatar
Awesome swap out! Will be watching this one.
Old 12-10-2009, 07:38 PM   #32
menace121978
menace121978's Avatar
subscribing to this one also...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 12-10-2009, 08:09 PM   #33
smokedat
smokedat's Avatar
What do u guys use for flaring lines i need to get a flaring kit i like this Matco tools kit
PREM DOUBLE FLARING KIT
* Quick slip-on yoke for easy use
* Ideal for brake, ATF, A/C, fuel and vacumm lines
* High quality, professional full polish chrome flaring bar
* For 1/4", 5/16", 3/8", and 1/2" O.D. tubing
* Easy operating, ball bearing flaring cone
* Matco Exclusive Stainless Steel Tube Cutter (SSTC1010) included
Old 12-10-2009, 08:14 PM   #34
smokedat
smokedat's Avatar
# Type: 45° Flaring Tool
# Maximum Pipe Capacity (Inch): 3/4
# Minimum Pipe Capacity (Inch): 1/8
Old 12-10-2009, 08:18 PM   #35
menace121978
just remember for the AN fittings they use a 37* flare. brake lines and such use the 45*.
my 45* is a craftsman and i'm really happy with it. right around $80. i had bought 2 cheapo ones from orielly and broke'em both.
i'm going to order a summit brand 37* for the an fittings.
"Dennis the Menace"
Old 12-10-2009, 08:22 PM   #36
lolife99
67-72 parts collector,…
lolife99's Avatar
subscribing,...
Keith
Convert to disc brakes.
Old 12-10-2009, 08:24 PM   #37
smokedat
smokedat's Avatar
the best one by far is this but its more expensive
Old 12-10-2009, 08:26 PM   #38
smokedat
smokedat's Avatar
Mastercool
Old 12-10-2009, 08:27 PM   #39
menace121978
Whoa!
"Dennis the Menace"
Old 12-10-2009, 08:27 PM   #40
smokedat
smokedat's Avatar
"Dennis the Menace" i agree the cheap flaring tools just don't work especially on stainless steel
Old 12-10-2009, 08:31 PM   #41
smokedat
smokedat's Avatar
has anyone used rubber type if so how is it holding up?
sample pic
Old 12-10-2009, 08:33 PM   #42
menace121978
ive heard they hold great when used with the right high psi hose clamps. not those pictured the screw type.
"Dennis the Menace"
Old 12-10-2009, 09:52 PM   #43
clinebarger
I did not know that. Out of the 100+ LS6/LS2s ive seen/worked on they all had a 243 casting number. are the heads production? Or a GMPP part?
clinebarger is offline   Reply With Quote
Old 12-10-2009, 09:55 PM   #44
Thealien
Thealien's Avatar
I recently bought the mastercool hydraulic flaring tool. It is "THE" flaring tool! The only flare die it doesn't have is the 37 degree and I "may" add it. I bought it just for the GM pushloc flare, everything else is a bonus. Anyone can make a good flare with that tool! It can be found for just under $300 if you look.
Old 12-11-2009, 01:04 AM   #45
smokedat
smokedat's Avatar
clinebarger
so i did some research on the net, and i think im finding that the 799 was a pre production ls6 head, and the 243 replaced them, but im also seeing some 06 corvettes with the 799 heads as well??
Casting number 799 is also an LS2 head. Came on some late 06 and up tbss and other LS2 vehicles. These are the mexico cast heads. Little rougher finish. Same basic head and flow though.
Old 12-11-2009, 01:06 AM   #46
smokedat
smokedat's Avatar
Thealien
Thanks for the recomendation will look into getting one.
Old 12-11-2009, 01:25 AM   #47
smokedat
smokedat's Avatar
Wilwood tandem chamber master cylinder 1 1/8 bore
Old 12-11-2009, 07:40 AM   #48
3r!c84
Badass
3r!c84's Avatar
how much was that little guy?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-11-2009, 09:29 AM   #49
78-5.3
78-5.3's Avatar
sample pic
i used factory tahoe fule lines in my truck im amazed it not used as much??
i got them from a wreck 2001 tahoe your engine being from a camaro? why not look a the fuel lines from that?? i did some slight rebending but it followed down the back of the engine on the transmission across to the chassis rair down to the tank where i modified it to suit my 78 job done im sure the camaro lines have a similar setup
78-5.3 is offline   Reply With Quote
Old 12-11-2009, 10:22 AM   #50
JohnC
JohnC's Avatar
This seems to be an awesome build. Definitely subscribing!
That willwood set up looks pretty sweet on there.
JohnC is offline   Reply With Quote
73c10, c10, cheyenne, ls1, swap
