Old 12-10-2009, 08:28 PM   #26
chevyrestoguy
chevyrestoguy's Avatar
Re: Ebrake question for rear disc conversion..?
The use of the emergency brake is mandatory if you're using the Cadillac Seville calipers. The reason is, the air gap between the brake pads and the rotor is set by the usage of the e-brake. The piston assembly has a ratchet-type mechanism that resets itself everytime you set the e-brake. If you don't use an e-brake on the Caddy calipers, then as the pad and rotors wear, your air gap increases and causes a long pedal when you push the brakes.
That's why when you find a set of Seville rear calipers in a wrecking yard, the pads are usually perfect because most people with big luxury boats that don't have to park on a hill never set the e-brake.
I did a ton of research on this subject, bought all the parts, but sold the truck I was going to do the conversion on. The parts are just sitting on the shelf in the boxes collecting dust.
chevyrestoguy is offline   Reply With Quote
Old 12-10-2009, 08:34 PM   #27
68 TT
Still plays with trucks
68 TT's Avatar
Great info, thanks for sharing.
I believe the same goes for the LT1 calipers. Mine would hang up some times and the e-brake lever would go way beyond its normal travel range when engaged. Cycle it a few times and the lever travel would return to normal and the calipers would work like normal again.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
