Old 12-11-2009, 10:30 AM   #26
WIDESIDE72
WIDESIDE72's Avatar
Re: Serpentine Setup
Originally Posted by Jim_PA View Post
I guess I fail to see the advantage. Seems like a much more intricate setup than the trusty old v-belt and pulleys
The water pump has to be a reverse rotation pump and be run by the "backside" or flat side of the belt to work correctly.
WIDESIDE72 is offline   Reply With Quote
Old 12-11-2009, 10:44 AM   #27
Jim_PA
I was referring to a serpentine swap in general.
Jim_PA is offline   Reply With Quote
Old 12-11-2009, 08:12 PM   #28
hchad18
hchad18's Avatar
Also on the car one the a/c and the alt set a little lower and apart. The truck version is up and together. I made a new pulley bracket for my smog pump area idler pulley because I thought it looked empty. I have one off a 91 blazer given to me because neighbor found a powder coated and chrome one. I think they look clean
hchad18 is offline   Reply With Quote
Old 12-11-2009, 08:27 PM   #29
Strut
Strut's Avatar
I have a early 90's s10 with a 4.3 in my back yard. What would I need to get to pull everything off and put it on my 350??
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 12-11-2009, 09:15 PM   #30
lclippard
lclippard's Avatar
just a note to those who need it, NAPA carries Dorman products, one of which is A/C delete pulleys w/ brackets. i have the catalog, if anyone needs a part number, let me know.
69 burb/01 yukon chassis
65 Comet Caliente 289 4 Door Sedan
99 Millenia S (supercharged) 4 Door Sedan
02 Yamaha R6
69 swb c10 http://67-72chevytrucks.com/vboard/s...36#post3799136
building with a buddy:
85 C10 http://67-72chevytrucks.com/vboard/s...94#post3708194
lclippard is offline   Reply With Quote
Old 12-11-2009, 10:01 PM   #31
BossHogg69
motor exploder
BossHogg69's Avatar
any big block setups??? I bought a serp setup off a '89 7.4L dually to use on the 468 I just built for my '69, but I haven't installed it. Would be interested in some BBC pics if you guys have any!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-11-2009, 10:17 PM   #32
cjaj70
Don't have any pictures handy but, just installed same type of serpentine on a '71. The fittings on the power steering were different, we had a custom hose made and good to go. We also had to order a swivel thermostat housing. Will try to get pictures when I get some free time.
cjaj70 is offline   Reply With Quote
Old 12-12-2009, 02:19 AM   #33
BossHogg69
motor exploder
BossHogg69's Avatar
Yeah, I knew the hoses were different (flared vs. o-ringed) and I have a polished aluminum swivel water neck already. Love to see pics when you get a chance, thanks.
Adam
Old 12-12-2009, 11:02 AM   #34
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
I feel that a serpentine drive is a more reliable, simpler, quieter, longer-lived system.
I did the same as quite a few others-- got my whole system off an early '90s 5.7 truck.
I used the original rams horns exhaust and did have to make a couple of modifications, including,
1. Had to get a smaller, 18-inch reverse rotation fan to fit the original shroud. Also had to drill out the holes in the new fan to make it fit the stock fan clutch.
2. I did not drill the additional hole in the right head for the bracket. So far I haven't had any problems, but admittedly haven't driven it that much either.
3. Changed the relief valve in the back of the late model steering pump so my old hose would hook right up to it.
4. Modified one of the bracing rods to fit my older intake manifold.
5. Modified one of the power steering pump brackets to fit over the rams horn.
I documented all this in my build thread. It all worked out quite well and I'm happy with it.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 12-12-2009, 11:44 PM   #35
cjaj70
We also had to go to local alternator shop and get a late model plug and rewire the alternator. If you have any other questions or need different pics just let me know.
Old 12-12-2009, 11:51 PM   #36
BossHogg69
motor exploder
BossHogg69's Avatar
thanks a lot for the pics - that helps me out quite a bit!
Adam
Old 12-13-2009, 12:04 AM   #37
cjaj70
No problem, if there is anything else you need a picture of or anything else can do to help just holler.
Old 03-29-2010, 09:22 PM   #38
dukkie
My Spoon Is Too Big
dukkie's Avatar
Originally Posted by Sammy View Post
If you have that sorta cash they sure do look nice agreed. Mine came off a 93 Chevy 5.7. Removed the upper tension pully and had it powder coated with silver. Since I wasn't installing A/C I used a A/C delete pulley. And added twin Virgo Fans. Don't forget to get the upper and lower rad hoses. Especially the upper hose, in my case it was a bit longer over stock to reach the radiator. For the power steering pump swap your fitting out with your old pump fitting and that will save you from getting new line.
Tell me more about the ac delete pully.. Do you still use the original ac braclet?
1972 C20, 03-14-10 Build Thread
2000 Silverado 4.8L, 11-04-13 (Currently Parting)
1999 Silverado 5.3L, 07-07-14. (Engine Donor)
2015 Ram 05-20-15 (Daily Driver)
dukkie is offline   Reply With Quote
Old 03-29-2010, 09:47 PM   #39
dwcsr
Hollister Road Co.
dwcsr's Avatar
Mine is from a 91 and I used the A/C delet pulley. You do need a shorter belt
Old 03-30-2010, 01:05 AM   #40
dukkie
My Spoon Is Too Big
dukkie's Avatar
So the waterpump i took off the 94 suburban will not work? Or is that the reverse pump that i need?
Old 03-30-2010, 07:59 AM   #41
Sammy
You must have the reverse water pump. (Also if you notice the pic with the A/C pump installed above) There is a rider pulley below the A/C pump, I had to remove that also using the delete a/c pulley because it would reject the serp belt whenever I would throttle the motor. Those delete pulleys are available on line and can be special ordered thru places like Auto-zone and such but be ready for some head scratching there. I ordered on line after doing a search on line for DELETE A/C PULLEY. That 94 surburban if it had a serp originally should be a reverse water pump.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-06-2010, 11:03 PM   #42
dukkie
My Spoon Is Too Big
dukkie's Avatar
I also used a 94 suburban
got everything for 100 bucks at a junk yard
Old 04-06-2010, 11:56 PM   #43
joeelutz
joeelutz's Avatar
Hey, I'm not trying to hijack your thread, but I have this complete GM setup that I am selling for $350 because I went with a Vintage Air Front Runner setup. It has all the pulleys, brackets, GM waterpump, new alternator, new ps pump, used compressor, and new tensioner. I also will include all the Stainless allen bolts to attach it. The brackets were media blasted and clear coated. Just PM me if interested.
joeelutz is offline   Reply With Quote
Old 04-07-2010, 10:48 AM   #44
chevelle
instagram "footbraker67"
chevelle's Avatar
Mines off of a 96 or so 4.3 blazer. I have TBI heads so i didnt have to drill any holes in them. no problems so far. and the best part is the hole thing was free! i swapped a motor in a customers blazer and the used motor came with everything. These pics are kinda old, since then i have installed a Vintage Air kit and the hoses bolt right up to the compressor with one of their adapters.
1967 lwb, bigwindow, factory air (converted to Vintage Air), custom option,4.5- 6 drop, TBI injected 355, 700r4, 5 lug, daily driver.
1967 Chevelle Malibu Drag car, 355, brodix heads and intake, powerglide, 10.82 @ 123 mph
1966 chevelle malibu, Street/strip, 355, spare parts from my other chevelle, 12.82 @104 mph
1968 lwb parts truck
chevelle is offline   Reply With Quote
Old 04-07-2010, 03:10 PM   #45
1quik70
[QUOTE=SactoJim;3667299]Here's mine....Concept One.
4,000 miles and no problems except I studded the mounting points on the heads cuz I had a bolt shear off.
QUOTE]
Can I ask what your advantages of running a serp. setup is since you are running an individual belt for each accessory anyway? Not a big deal, just wondering why you went that route over conventional. Also, who's Power steering pump is that? I need something like that to give me more room under the hood of my Big Block Nova!
1quik70 is offline   Reply With Quote
Old 04-07-2010, 07:00 PM   #46
joeelutz
joeelutz's Avatar
Here are some pics of the new Front Runner setup. I really like it. It's very compact and well designed. I guess it should be for $2000. I'll take $350 for my old serpentine setup.
Old 04-07-2010, 07:43 PM   #47
BOZO
Old School
BOZO's Avatar
I installed a setup from a 1999 4.3 V6 from a full size truck which looks just like the one in Chevelles post. It fit rather well, but let it be known that you cannot use the tall Edelbrock valve covers. The AC bracket barely clears the stock valve cover on the drivers side. Even using Edelbrock Signature series valve covers, I had to slightly modify the AC bracket and shim up the AC pump.
Nevertheless, I am very pleased with the swap. I now have a high amperage alternator and the best AC compressor that Chevrolet makes. If my computer guru ever gets back from Hawaii, I will be able to post a step by step installation.
#1 Project...69 Chevy swb Fleetside (Dad's truck)
#2...1983 El Camino SS (Choo Choo Custom)
#3...1974 Datsun truck (4.3L V6/4L60E)
#4...1951 Cadillac Limo (1975 Caddy running gear)
#5...1938 Dodge M38 3/4 ton Military truck
#6...1968 Sportster XLCH trail bike
5 GMC & Chevy parts trucks 68 to 72
Last but not least;
My 1978 Harley Davidson Electraglide
(trusted & reliable companion for the last 30 years)
BOZO is offline   Reply With Quote
Old 04-07-2010, 08:18 PM   #48
handsomerob
handsomerob's Avatar
this is the factory BB kit from GM performance:
Part Number: 19172805
Retails for around $900
See it here
Comes with everything you need.
handsomerob is offline   Reply With Quote
