12-12-2009, 02:54 AM | #1 |
Ticking Wheel
My front passenger side wheel is ticking. I figure it's a bearing problem, but I don't really have time to do the brakes/bearings this weekend, and I need the truck to haul some lumber for a fence. Am I going to cause any catastrophic damage if I drive the truck about 100 miles this weekend? I don't know much about bearings and whatnot.
1972 Chevy C-10 ~ 188,000 miles give or take |
12-12-2009, 06:42 AM | #2 |
Re: Ticking Wheel
If it is a bearing then you could have some real problems very shortly.
Do you have trim rings on your wheels? They can cause a tick. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
12-12-2009, 08:03 AM | #3 |
Re: Ticking Wheel
If you just noticed it started making the noise it should good for a few more careful miles.But,you didn`t hear that from me.I ain`t recommending squat.
Take the time to jack the wheel up to check for wear or slop.Also,listen to and watch it spin.Then decide.
12-12-2009, 12:55 PM | #4 |
Re: Ticking Wheel
Most of the time I have had a ticking noise it was as foreign object. Does it tick only on pavement or all the time? Either a rock or nail/bolt in the tread will cause this too.
12-12-2009, 03:47 PM | #5 |
Re: Ticking Wheel
Yeah, I was thinking there may be something in there, but I checked the tire, and it only ticks when it's on the ground. When it's up in the air, it is quiet. It's okay, though, brakes/rotors/bearings are getting done tomorrow after all. . .
12-12-2009, 08:53 PM | #6 |
Big Red - Now its a SWB!
Re: Ticking Wheel
that's what I was thinking too! I have an explorer with aggressive tires and live on a gravel road so this happens all the time to me....once you get up to about 60 it's usually out!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 12-12-2009 at 08:54 PM. |
12-12-2009, 08:57 PM | #7 |
Re: Ticking Wheel
I have seen loose brake pads do this also cotter pins hitting on a beat up bearing dust cap.
12-13-2009, 02:04 AM | #8 |
Re: Ticking Wheel
Well, we'll see. Tomorrow's brake/bearing day. Anything that I should know in order to make this go smoothly??? Specifically any tips for packing the bearings with grease? Just grease 'em up and pack 'em in?
1972 Chevy C-10 ~ 188,000 miles give or take Last edited by Mike Quillici; 12-13-2009 at 03:47 AM. Reason: More info. |
12-13-2009, 06:04 AM | #9 |
Re: Ticking Wheel
Don't just wipe grease on the bearings and put them in. You have to work the grease into the bearings. Put some grease in the palm of one hand, take the bearing in the other hand, and with the large side towards the grease, just tap the bearing into the grease in your hand. After a bit, you'll notice the grease start appearing at the
top, small, side of the bearing. After you've done that all the way around the bearing, THEN you wipe some on the outside of the bearing, (now your bearing is packed), and put it in. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
12-13-2009, 06:43 AM | #10 |
Re: Ticking Wheel
The last time I had a ticking noise from a wheel it was coming from the loose center cap. Before that it was the busted joint on my right front axle in the 4x4 but that was a little more than a tick.
12-14-2009, 03:41 AM | #11 |
Re: Ticking Wheel
Alright. New bearings, rotors, and brake pads. The pads were so warn, that they were metal on metal in some places. Took her for a spin, and she stops. So, I couldn't ask for much more. Thanks everyone.
