![]() Join Date: Jun 2004
1972 Distributor - I need the correct one.
We have a 1972 C10 with original 402 and someone in the past put in an HEI distributor. We are trying to put this truck back to an original points type distributor. However, I can't find any source to determine what the correct number is for this year and engine combination.
It is a 1/2 ton C10 with 402 and automatic transmission. Can anyone point me to a source or tell me what the correct distributor is? Thanks, Mike |
Hollister Road Co.
Re: 1972 Distributor - I need the correct one.
Are you looking for original with the tag on it or a rebuilt?
Cardone 381835 is for 71-72 402 The original part number is 1112064 I suspect that its the same as a 350 of that year with a different curve on the advance. |
I'm hoping to find an original that I can rebuild. Are you pretty sure on this number being the correct one?
TOTY 2006
![]() Join Date: Dec 1999
Parts Interchange show the same 1112064 id.
Usage, 1971-1972 C-10 - C30 Cheverolet and 1500 to 3500 GMC truck with 402ci V-8 - All Transmissions. |
If you do this, buy a pertronix or crane ignition module to install inside, distributor will look stock but perform like a hei best of both worlds. I have done this to two and it works flawlessly.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle Last edited by 71 super; 12-13-2009 at 10:09 PM. |
70 Chevrolet=Obsession
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
Thanks everyone for the help. I would never have found that number.
If you know anyone that has this distributor, please let me know. I haven't found any for sale yet but I'm sure they are out there. |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Maybe I can help you. I bought a 72 BB Burb a couple of months ago and it has a HEI in it. As I was leaving with the Burb the seller gave me a box of parts and there is a distributor in it. I never looked at the distributor assuming it was the original from the 402. Its -38C right now and the box is in my unheated garage. Tomorrow whe the sun is up and its a balmy -25C I'll get the disributor and post the numbers off it on this thread. If its what you need and you want it we'll figure something out.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Thank you Already Gone!
Would you happen to have a good 402 oil pan?? |
Active Member
![]() Join Date: Dec 2003
I have a 72, 350 and the dis. # is: 1112047. Don't know if this helps.
No thank you. I would really like to have an original which appears to be 1112064. Thanks
Please let me know if anyone has one. I hope Already Gone has one. |
I think you are in luck.. I wrote the numbers down off my old distributor and I got 1112064 and just to the right of those numbers it has 2A7.
I've attached some pics of the distributor.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 12-14-2009 at 08:28 PM. |
I'd love to have it. I sent you a PM to have you call me so we can work something out. Thanks
