#501 |
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
i dont know buddy... 79gmc5.3 is going to take a stock compressor and lines over to brp and have them test fit it. i'm hoping it works... if not, the best solution is the conversion plates and high mount a/c bracket and compressor. that is maybe another option though(tbss compressor)
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#502 |
Slots go on anything!
I thought Bob looked at a TB compressor, and it was a no go? IIRC, it was close, but the frame still needed to be notched a little bit for clearance, and it was about an inch from the idler arm. I thought that was why he decided to go with the high mount compressor.
#503 |
Yeah I think you are correct. Someone did look into the TBSS compressor, but don't remember what the issue was.
#504 | ||
Future: 86 on GenIV power!
![]() Join Date: Jun 2009
Dennis; Codys87 has the BRP engine mounts and it appears he is using a 96 compressor. Quote:
#505 |
rongstad, thanks alot for posting those and checking your book marks. i'm going to pm Cody and see what the deal is...
#506 |
very nice build!!!!
#507 |
Next project: 1970 K10
Hey slacker, what's up? No posts on this thread from you in like, 4 days!!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#508 |
![]() and actually i'm waiting to hear from a fellow board member if the BRP mounts are going to work like i had hoped ![]() quick question buddy, can you shoot me a link to the fuel lines and adaptors you used and how you ran the driverside tank fuel line? did you use the factory steel fuel line that goes across the crossmember?
#509 |
I have my receipts and notes at home, I'll look that stuff up tonight. Not sure if I have pics of the left to right lines or not, but yes, I did use the OEM steel lines that run across that crossmember right behind the cab. I just replaced the fuel lines that connect from the SU to the lines with the same Summit high PSI hose I used throughout.
#510 |
Bob hope you dont mind.....
C&P You will need to swap the sending units to the 87 models. The 87's had TBI and used in-tank pumps. The sending unit part numbers are: * Dorman p/n 692027 for the driver side, $94 at rockauto.com * Dorman p/n 692044 for the passenger side, $101 at rockauto.com I used ACDelco fuel pumps: * AC Delco EP381 in-tank pumps. $69 at getgmparts.com And a high pressure tank switch valve: * Pollak high psi tank selector valve. $83 at JC Whitney, p/n ZX812705U And be sure to use fuel injection hose, not regular fuel hose. Also use good fuel injection clamps, not the typical worm gear clamps. I ordered FI rated 5/16" hose for the return lines, and Summit's -6 hose for the pressure side. FI rated clamps on all the tank and valve connections, and Summit's Snap-Tite AN fittings on the Vette filter/regulator and fuel rail. This is the hose: Summit SUM-220785 - Summit Racing® Twist-Tite Hose - Overview - SummitRacing.com |
#511 |
6.0L power.........
Hey Dennis I still have not had a chance to get to BRP but I will, don't give up on me. With Christmas and work it has been tough. I have been pming Bob and he did not think they would work. I also talked to a friend who is a stress engineer where I work and he did not think knocking the fram in that area would be a problem.
![]() Russell
What ever the mind of man can conceive......... he can achieve! ![]() My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914 1979 GMC Sierra 6.0 L 4L60E ![]() 1995 Mustang GT 347 ![]() |
#512 |
More part #'s:
Dorman 800-120: 5/16" adapter for the inlet end of the filter (return line) (need 1) Dorman 800-121: 3/8" adapter for the inlet end of the filter (feed line) (need 1) Dorman 800-155: 3/8'' x 12'' Double Bead Line, cut in half and use one on the outlet end of the filter (need 1) RUS-640850: 3/8" Fuel rail fitting adapter (need 1) * RUS-660350: -6AN male to -6 AN male, use at the outlet end of the filter (need 1) * RUS-660650: -6AN tube sleeve (need 1) * RUS-660570: -6AN tube nut (need 1) SUM-220701: -6AN straight hose end, barbed for Twist-Tite hose (need 2) SUM-220785: -6AN Twist-Tite rubber hose, 20' length (won't need this much though) IDE52F15: 5/16" FI hose clamps IDE52F16: 3/8" FI hose clamps STIFI-503: 5/16" FI hose, 10' length (for return lines) The Dorman numbers I got from Rock Auto. In a pinch, AutoZone and the like usually stock part #'s 800-120 and 800-121, but I don't know the price. The Russell and Summit (RUS, SUM) numbers are from Summit Racing. The FI hose clamps and 5/16" FI hose I got from www.autobarn.net I did also find the hose clamps locally, if you have someone that can get Auveco parts, those part numbers are 15861 (5/16") and 15862 (3/8"). (*) These will get used on the double bead line, as well as the trans cooler lines if you need to go from steel line to SS hose. The tube nut gets slipped on, then the tube sleeve, then a 37° flare put on the line. The the RUS-660350 double -6AN male threads to the nut, then the SUM-220701 swivel end on the hose threads onto that.
#513 | |||
![]() Quote:
#514 |
I have car A.D.D.
Dennis, I am glad to see you are keeping things coming. That has been the hard thing for me since getting my truck. The delays between when I am able to get certain parts is why I don't have a build thread. (I know go ahead and take you shot).
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
#515 |
![]() speaking of build threads... new job, new thread....???!! ![]()
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() Last edited by menace121978; 12-23-2009 at 08:23 AM. |
#516 | |
6.0L power.........
Dennis: Please help me to be as patience as you are. I see all the things I need and know I don't have the money to go buy them, and it is driving me CRAZY!!!! ![]() ![]() ![]()
#517 |
![]() ![]() patience... its hard man. just imagine if you had the money and still had to hold back ![]() ![]()
#518 |
I have car A.D.D.
Wow, she must have got some cool...Shoes? Purses? Clothes? Whatever she enjoys spending money on. Because I am sure that you don't just have "a couple bucks" into that one.
And about seeing your truck in person...I am sure that will happen. Here or there, it will happen. Maybe I will start a build thread when time allows me to actually sit on here and type it all out one night. That might be fun and keep me motivated to do some more when I can.
#519 |
That's why I started my build thread Gerald.
#520 | |
Low & Fast!
#521 |
Me too. Stuff just shows up here at work all the time.
1974 Jimmy- 5.3/4L80e/NP241 |
#522 |
very very nice project... congrats...
#523 |
hello i've been looking and reading you whole thread and ur truck is so nasty i got alot ot tips from here just wanted to say ur truck is badass and i cant wait to see her all done looks badass!!!!
#524 |
#525 |
quick picture update... finally got the stones to go out and snap a few pics of the fuel system parts from 2 weeks ago!
