Old 12-17-2009, 12:58 AM   #26
Stitch
Location: Where I come from, it's cornbread and chicken...
Re: RPO E81 Fleetside Wood Floor
also, does the wood get installed from the bottom side...if not, what moves out of the way so the wood can be installed from the top?
Stitch is offline   Reply With Quote
Old 12-17-2009, 10:26 AM   #27
crossy's son
nothing beats that 'look' for the 'show' part of the truck, especially in a fleetside of all things. great job.
Mine- '91 GMC RCSB 2wd, 350tbi, 5 speed, 3.42 G80
-Dad/Me Projects/Toys
75 SWB Silverado Factory 454, Th400
87 SWB Silverado 305tbi, 700r4, 2.73's...17.4 @74mph
a couple dodge cummins trucks.
PLEASE DO NOT MESSAGE ME ABOUT FACTORY TACH DASHES, I AM NOT MY FATHER AND I KNOW VERY LITTLE ABOUT THEM. Thanks
crossy's son is offline   Reply With Quote
Old 12-17-2009, 02:24 PM   #28
JohnC
JohnC's Avatar
Originally Posted by Tex_50613 View Post
78 lb stepsides and 76 sb stepsides you could also get it, I had one of each with original wood floors in them in the last 10 years know I have the lb fleetside off a 75 still as I already stated and just was talking with my brother and he says that I still have the sb stepside with a wood floor out back of my father's place
The stepsides kept the wood floor up to 87. It's the fleetsides that were rare.
I agree you made the right decision Ray. It looks sweet with the urethaned wood, and not painted.
JohnC is offline   Reply With Quote
Old 12-18-2009, 09:20 PM   #29
ray_mcavoy
Thanks guys!!
Originally Posted by Fat Hoe
can the metal floor be unbolted from the bedsides and front panel by itself without taking the bed off the truck
No, I don't think it'd be very easy to take out the metal floor & leave the bedsides/front in place. Especially since the bed floor is what bolts to the frame and holds the bedsides/front.
It can be installed either way. I believe GM likely bolted the wood boards down to the cross sills and then bolted on the perimeter flange pieces to form a floor assembly. Then they probably bolted the wheel tubs, front panel, and bedsides onto that floor assembly just like with a steel floor. Finally, they painted the whole works.
In order to keep paint off the boards (and avoid lots of extra masking), we used a slightly different assembly procedure. We bolted the bedsides, front panel, and rear cross sill all together to form a "floor-less" bed. Then we bolted in the perimeter flange pieces and ran a bead of seam sealer (like factory) along where they join up to the bedsides/wheel tubs/etc. Next, I painted the inside of the bed while standing in the open area where the floor would eventually go.
We put the outside edge boards up in from the bottom, followed by the cross sills.
The remaining center boards went in from the top since only the front edge of those gets sandwiched under the flange along the bottom of the front bed panel. The rear edge of the boards simply lays into the notch in the rear cross sill. And those middle boards are held down by the steel strips/bolts that go between them.
Ray
ray_mcavoy is offline   Reply With Quote
Old 12-18-2009, 10:31 PM   #30
Stitch
that's an awesome write up...I subscribed to this thread...when I get around to doing the bed of the truck, I'll be sure to post pics for everyone to see...mine's a swb, so we'll see how much I have to fab up...I'm going to cut and prep my own boards...there's a couple of sites that show how the boards need to be cut for the strips to fit right and all...Ray, I can't thank you enough for this...I've had this on the to-do list for the truck because I haven't seen anyone do this to a swb...thank you again...
Chuck.
Old 12-18-2009, 10:55 PM   #31
ray_mcavoy
Hi Chuck,
You're welcome. That should make for a really unique bed having a wood floor in your swb.
I can't remember if I mentioned it earlier or not, but we used cross sills meant for a 67-72 wood floor fleetside to replace the rusty originals. They already have the correct height/profile which is about 1/2" or so shorter than ones for a steel floor (to account for the thickness of the wood). However, the 68-72 ones extend out farther (wider) under the bedsides than the 73-80 ones so I had to cut 3" or 4" off them to duplicate the originals. Finally, the bolt hole spacing pattern is different (due to different width boards) but the folks at MAR-K were able to supply us with some un-drilled.
Old 12-19-2009, 12:12 AM   #32
80SPORT
80SPORT's Avatar
The RPO E81 was popular in rural and farm areas;It was about the same as the tachometer option as percentage of build.
There was also a RPO E56 factory stake body on the chassis cab with a wood floor;these were very rare and if someone has one or has seen one please contact me.
80SPORT is offline   Reply With Quote
Old 12-19-2009, 12:30 AM   #33
Stitch
Originally Posted by ray_mcavoy View Post
Hi Chuck,
thanks for the info...didn't think about getting them from a 67-72...that would probably be alot easier to find...I was just going to use some C channel, but if I could find original parts and somehow use them that would be alot better...also, when you talk about bolt spacing and ordering them with un-drilled, "them" would be the strips between the wood?...also, you just ordered the plain steel ones and painted them I'm assuming...I plan on doing that also, my truck is blue and white two tone and I think the blue will look good on the strips like in your bed...thanks again for the info...
Chuck.
Old 12-19-2009, 01:08 AM   #34
bigblock73
yeller
bigblock73's Avatar
Ray, your truck...and bed, look fantastic! I always wondered why GM never offered this option is short fleets.
bigblock73 is offline   Reply With Quote
Old 12-19-2009, 02:09 AM   #35
ray_mcavoy
Hi Chuck,
Regarding the bolt spacing, and getting "them" undrilled, I was talking about the replacement 67-72 style cross sills ... the pieces that run side to side under the bed floor. In addition to the smaller 1/4" holes to bolt down the boards, these also have larger 1/2" holes going through them for the bed-to-frame bolts. And some welded-on reinforcement plates in those locations. The un-drilled cross sills we got from MAR-K included those reinforcements but they left them un-welded so we could position them as needed to line up with the mounting holes in the 73-80 frame.
As for the strips that go between the boards, MAR-K had them for this application with the holes pre-punched. They're square holes for 1/4" carriage bolts. MAR-K does offer special carriage bolts with a splined shank (instead of square) for use in round holes (like if you get undrilled bed strips). The factory bolts in this bed were actually that splined type.
Yes, we ordered the bare steel bed strips, lightly sanded, primed, and painted them with the same paint I used on the rest of the truck. I sanded/primed/painted the heads of all the bolts too. As well as the offset washers that are countersunk into the wood around the bed-to-frame bolts.
Thanks for the compliments Jeff!
Old 12-19-2009, 06:23 AM   #36
KQQL IT
At the body shop.
KQQL IT's Avatar
^ Very very nice
Old 12-19-2009, 08:49 AM   #37
Stitch
Hi Chuck,
once again, excellent information...thanks alot...
Chuck.
Old 12-20-2009, 04:32 AM   #38
BIG10
BIG10's Avatar
That is sweet. I've never seen a fleetside. I learn something new everyday on this board. You guys did a fantastic job.
Jay
1978 Big 10 Silverado, 355 + 700R4 + 3.42 + factory tach + A/C + dual tanks + working cruise control = awesome highway cruiser.
BIG10 is offline   Reply With Quote
Old 03-06-2010, 11:45 PM   #39
djracer
djracer's Avatar
I Agree!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-07-2010, 03:02 AM   #40
thrtsxchambers
thrtsxchambers's Avatar
I have heard the fleetside wood floors were rare. I always wanted to put a wood floor in mine and found a company that makes one that just lays over the metal floor but I could 2 trucks for the price of the floor. Good lookin work.
thrtsxchambers is offline   Reply With Quote
Old 01-02-2013, 02:24 AM   #41
K20chevy
K20chevy's Avatar
Looks absolutely amazing! I just wouldn´t put anything in the bed anymore after making it look so great....
Too bad I still have to use my bed, otherwise that would be a great addition to my truck as well!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
Old 01-02-2013, 03:25 AM   #42
JJK
JJK's Avatar
GREAT job Ray,
Did the fab shop you found replicate all the required pieces or only the one's needing replacement?
John
1977 C3500 (Dually, Lo-Buckets, Regular Cab, 454, TH400, 4.10)
1977 Jimmy (Hi-Buckets, 350, 700R4, 3.73)
JJK is offline   Reply With Quote
Old 01-02-2013, 04:37 AM   #43
INSIDIOUS '86
INSIDIOUS '86's Avatar
This thread is from 2009 guys. Happy new year lol
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-02-2013, 07:36 PM   #44
ray_mcavoy
Thanks for the compliments guys!
They were able to duplicate all of the parts that needed replacement. That included the rear cross sill (which has a notch to hold the ends of the boards) along with most of the perimeter flange pieces that bolt to the bedsides & wheel tubs to make the transition to the wood. The pieces aren't overly complicated so I think most any shop with a large sheetmetal brake and a bead roller could do the job.
Old 01-02-2013, 08:16 PM   #45
meatwagon83
meatwagon83's Avatar
i was actually thinking of doing this in my dually
meatwagon83 is offline   Reply With Quote
Old 01-04-2013, 07:14 AM   #46
K20chevy
K20chevy's Avatar
Make sure to post pictures!
Old 01-05-2013, 12:06 AM   #47
esbstuff
Are you sure they quit the wood floor 8' fleetsides in 80? I was sure I ran across an injected 87 that was a wood floor truck... If the scrapers haven't got to it, the truck was wrecked (hard) and was sitting in a field a few years ago. I might have to go and take a peek to see if it is still there. But no promises as it was extremely rusty the last time I saw it...
esbstuff is offline   Reply With Quote
Old 01-05-2013, 09:57 AM   #48
Vbjunker
Vbjunker's Avatar
Great write up and beautiful job. Not something you see every day.
Vbjunker is offline   Reply With Quote
Old 01-05-2013, 03:18 PM   #49
MusicMan70
MusicMan70's Avatar
My 73 wood bed and date coded...
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 01-05-2013, 10:51 PM   #50
ray_mcavoy
Well, I haven't seen this option listed or mentioned in any of the 81-up factory literature like it is in the equivalent 73-80 documents. That would include the vehicle info kits from the GM Heritage Center (http://www.gmheritagecenter.com/gm-h...tion-kits.html) as well as the sales brochures which can be seen online at: http://brochures.slosh.com/
If that truck is still there and still has the SPID sheet I'd be curious to see if it lists E81 on there. If it doesn't, someone probably swapped a 73-80 bed onto that 87.
Thanks for sharing those pics! That's pretty cool that yours still has the date code visible! I don't recall seeing that on Dad's 77 but the old boards were weathered and worn a lot worse than yours.
Your pics also confirm something that I was previously a bit unsure about. That is those small carriage bolts that go directly through the boards in the rear/outer corner sections. I had a feeling they were factory since they go into existing cross sill holes but couldn't rule out the possibility that Grampa or Dad added them years ago to hold down warped/cupping boards. I'm glad to see that they do indeed belong there
