12-17-2009, 02:03 PM | #1 |
v8 rad ?
whats everyone using for a rad in converting to v8 without breaking the bank? i am going bbc 454.i don really want to cut up rad support .dont mind drilling a couple extra holes. some where i seen something about using a dodge van rad?
12-17-2009, 03:41 PM | #2 |
Re: v8 rad ?
I havent started making it fit but I plan on using a radiator with dual electric fans from an ls1 camaro.
12-17-2009, 04:03 PM | #3 |
Hollister Road Co.
Re: v8 rad ?
Start with what you have a try a Mark VIII fan or a Taurus Fan on it.
12-17-2009, 04:52 PM | #4 |
Re: v8 rad ?
i have the stock rad and engine fan in my truck and it runs cool
12-17-2009, 06:19 PM | #5 |
Hollister Road Co.
Re: v8 rad ?
The stock radiator is heavy duty by todays standards
12-17-2009, 06:39 PM | #6 |
Re: v8 rad ?
I was running the stock 6 cylinder radiator with a shroud and had no problems with my 283 (cam, 4bbl). This go around I picked up a larger radiator out of a 57 big truck, It is 1" thicker (3" total) a a little wider and a little taller. I am going to run it with the same shroud. Engine this time is a 350 but with air so I will have a condenser. The factory v8's had sheet metal that moved the radiator about 4-5" behind the support and closer to the engine. I did not move mine. I figure if I have problems I will add an electric fan to it I have lots of room.
Later: Here is a photo of the radiator shroud mockup. The fan blade will fit inside the shroud at the circle without any spacers.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 12-19-2009 at 01:44 AM. |
12-18-2009, 10:26 PM | #7 | |
Re: v8 rad ?
i will get all of the engine swap work leading up to rad done first! Last edited by 56 3100; 12-18-2009 at 10:28 PM. Reason: spelling |
