Old 12-17-2009, 04:35 PM   #1
Normy71
Torque specs for a L33 5.3 vortec
Hi I'm looking for the bolt Torque specs for a L33 5.3 vortec? I was sure I saw it here some place?
also with this being all aluminium engine do I need to put anything on these bolts before I torque them in?
What about detailing the engine should I paint it or just leave it how it?
Tell me what you think!
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 12-17-2009, 04:41 PM   #2
mindhive
Re: Torque specs for a L33 5.3 vortec
I would say you need anti-seize on good clean bolts to get proper torque on them. Dont know about the torque specs.
mindhive is offline   Reply With Quote
Old 12-17-2009, 04:45 PM   #3
Lobie
This is for the LS1. Should be very similar.
EDIT: Trying to attach it
Lobie is offline   Reply With Quote
Old 12-17-2009, 04:53 PM   #4
Lobie
here
Old 12-17-2009, 06:12 PM   #5
Normy71
Do you have a link to this page as I can't read it must be getting old? or I need some glasses.
Old 12-17-2009, 06:51 PM   #6
Clyde65
Clyde65's Avatar
LM4
The LM4 was an aluminum block version of the LM7, and had a short production life. It should not be confused with the L33.
LM4 applications:
* 2003-04 Chevrolet TrailBlazer EXT
* 2004 GMC Envoy XL
* 2004 Chevrolet SSR
L33 Vin code "B"
The L33 was an aluminum block version of the LM7, and was referred to as the Vortec 5300 HO in marketing materials. Power increased by 15 hp (11 kW), to 310 hp (230 kW), over the LM7, and torque was unchanged. It was only available on extended cab 4WD pickup trucks. Only 25% of trucks made in 2005 had the L33 engine.
325ftLbs torque per....
http://en.wikipedia.org/wiki/GM_Vortec_engine
Clyde65
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-17-2009, 06:58 PM   #7
Normy71
Thanks but I'm looking for the Torque Specs for the bolts on this L33
Old 12-17-2009, 07:26 PM   #8
faribran
if rebuilding.... i understand its very important to blow out bolt holes with compressed air.... easy to damage block if fluids are trapped in bottom of bolt hole.
faribran is offline   Reply With Quote
Old 12-18-2009, 09:43 AM   #9
Normy71
ttt
Thanks!
Old 12-18-2009, 09:52 AM   #10
Shon
Most of the LS1 bolts are torq to yield unless you replace them with ARPs.
Where you purchasing the bolts? The can provide you with the information you need.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 12-18-2009, 08:36 PM   #11
Lobie
Pm me your email and I will send them to you. They are a PDF file that was to big to attach to this forum.
Old 12-18-2009, 08:44 PM   #12
Thealien
Thealien's Avatar
This is for an LS2 but should apply?
Fastener Tightening Specifications
Application
Specification
Metric
English
Camshaft Position (CMP) Sensor Bolt
12 N·m
106 lb in
CMP Sensor Wire Harness Bolt
12 N·m
106 lb in
Camshaft Retainer Bolts - Hex Head Bolts
25 N·m
18 lb ft
Camshaft Retainer Bolts - TORX® Head Bolts
15 N·m
11 lb ft
Camshaft Sprocket Bolts
25 N·m
18 lb ft
Clutch Pressure Plate Bolts
70 N·m
52 lb ft
Connecting Rod Bolts - First Pass
20 N·m
15 lb ft
Connecting Rod Bolts - Final Pass
85 degrees
Coolant Air Bleed Pipe and Cover Bolts
12 N·m
106 lb in
Coolant Temperature Sensor
20 N·m
15 lb ft
Crankshaft Balancer Bolt - Installation Pass to Ensure the Balancer is Completely Installed
330 N·m
240 lb ft
Crankshaft Balancer Bolt - First Pass - Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes
50 N·m
37 lb ft
Crankshaft Balancer Bolt - Final Pass
140 degrees
Crankshaft Bearing Cap M10 Bolts - First Pass in Sequence
20 N·m
15 lb ft
Crankshaft Bearing Cap M10 Bolts - Final Pass in Sequence
80 degrees
Crankshaft Bearing Cap M10 Studs - First Pass in Sequence
20 N·m
15 lb ft
Crankshaft Bearing Cap M10 Studs - Final Pass in Sequence
51 degrees
Crankshaft Bearing Cap M8 Bolts
25 N·m
18 lb ft
Crankshaft Oil Deflector Nuts
25 N·m
18 lb ft
Crankshaft Position (CKP) Sensor Bolt
25 N·m
18 lb ft
Crankshaft Rear Oil Seal Housing Bolts
30 N·m
22 lb ft
Cylinder Head M11 Bolts - First Pass in Sequence
30 N·m
22 lb ft
Cylinder Head M11 Bolts - Second Pass in Sequence
90 degrees
Cylinder Head M11 Bolts - Final Pass in Sequence
70 degrees
Cylinder Head M8 Bolts - in Sequence
30 N·m
22 lb ft
Cylinder Head Coolant Plug
20 N·m
15 lb ft
Engine Block Coolant Drain Hole Plug
60 N·m
44 lb ft
Engine Block Coolant Heater
40 N·m
30 lb ft
Engine Block Oil Gallery Plug
60 N·m
44 lb ft
Evaporative Emission (EVAP) Canister Purge Solenoid Valve Bolt
50 N·m
37 lb ft
Exhaust Manifold Bolts - First Pass
15 N·m
11 lb ft
Exhaust Manifold Bolts - Final Pass
20 N·m
15 lb ft
Exhaust Manifold Heat Shield Bolts
9 N·m
80 lb in
Exhaust Manifold Studs
20 N·m
15 lb ft
Flywheel Bolts - First Pass
20 N·m
15 lb ft
Flywheel Bolts - Second Pass
50 N·m
37 lb ft
Flywheel Bolts - Final Pass
100 N·m
74 lb ft
Front Cover Bolts
25 N·m
18 lb ft
Fuel Injection Fuel Rail Bolts
10 N·m
89 lb in
Ignition Coil Bracket-to-Valve Rocker Arm Cover Stud
12 N·m
106 lb in
Ignition Coil-to-Bracket Bolts
10 N·m
89 lb in
Intake Manifold Bolts - First Pass in Sequence
5 N·m
44 lb in
Intake Manifold Bolts - Final Pass in Sequence
10 N·m
89 lb in
J 41798 M8 Bolt
25 N·m
18 lb ft
J 41798 M10 Bolts
50 N·m
37 lb ft
Knock Sensor Bolts
20 N·m
15 lb ft
Motor Mount Bracket Bolts
50 N·m
37 lb ft
Oil Cooler Bolts
12 N·m
106 lb in
Oil Filter
30 N·m
22 lb ft
Oil Filter Fitting
55 N·m
40 lb ft
Oil Level Indicator Tube Bolt
25 N·m
18 lb ft
Oil Level Sensor
20 N·m
15 lb ft
Oil Pan Closeout Cover Bolt - Left Side
9 N·m
80 lb in
Oil Pan Closeout Cover Bolt - Right Side
9 N·m
80 lb in
Oil Pan Cover Bolts
12 N·m
106 lb in
Oil Pan Drain Plug
25 N·m
18 lb ft
Oil Pan M6 Bolts - Oil Pan-to-Rear Oil Seal Housing
12 N·m
106 lb in
Oil Pan M8 Bolts - Oil Pan-to-Engine Block and Oil Pan-to-Front Cover
25 N·m
18 lb ft
Oil Pressure Sensor
35 N·m
26 lb ft
Oil Pump Cover Bolts
12 N·m
106 lb in
Oil Pump Relief Valve Plug
12 N·m
106 lb in
Oil Pump Screen Nuts
25 N·m
18 lb ft
Oil Pump Screen-to-Oil Pump Bolt
12 N·m
106 lb in
Oil Pump-to-Engine Block Bolts
25 N·m
18 lb ft
Spark Plugs
15 N·m
11 lb ft
Throttle Body Bolts
10 N·m
89 lb in
Timing Chain Dampener Bolts
25 N·m
18 lb ft
Valley Cover Bolts
25 N·m
18 lb ft
Valve Lifter Guide Bolts
10 N·m
89 lb in
Valve Rocker Arm Bolts
30 N·m
22 lb ft
Valve Rocker Arm Cover Bolts
12 N·m
106 lb in
Water Inlet Housing Bolts
15 N·m
11 lb ft
Water Pump Bolts - First Pass
15 N·m
11 lb ft
Water Pump Bolts - Final Pass
30 N·m
22 lb ft
© 2009 General Motors. All rights reserved.
Old 12-18-2009, 08:53 PM   #13
Thealien
Thealien's Avatar
or a bigger list
Engine Torque Specs
Application Spec
Accelerator Control Cable Bracket Bolts 89 lb in
Air Conditioning Compressor Bolts 37 lb ft
Air Conditioning Compressor Bracket Bolts 37 lb ft
Air Conditioning Idler Pulley Bolt 37 lb ft
Air Conditioning Tensioner Bolt 18 lb ft
Air Injection Reaction (AIR) Pipe-to-Exhaust Manifold Bolts 15 lb ft
Camshaft Retainer Bolts 18 lb ft
Camshaft Sensor Bolt 18 lb ft
Camshaft Sprocket Bolts 26 lb ft
Catalytic Converter Nut 18 lb ft
Connecting Rod Bolts - First Design (First Pass) 15 lb ft
Connecting Rod Bolts - First Design (Final Pass) 60 degrees
Connecting Rod Bolts - Second Design (First Pass) 15 lb ft
Connecting Rod Bolts - Second Design (Final Pass) 75 degrees
Coolant Temperature Gauge Sensor 15 lb ft
Crankshaft Balancer Bolt (Installation Pass-to Ensure the Balancer is Completely Installed) 240 lb ft
Crankshaft Balancer Bolt (First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes) 37 lb ft
Crankshaft Balancer Bolt (Final Pass) 140 degrees
Crankshaft Bearing Cap Bolts (Inner Bolts-First Pass in Sequence) 15 lb ft
Crankshaft Bearing Cap Bolts (Inner Bolts-Final Pass in Sequence) 80 degrees
Crankshaft Bearing Cap Side Bolts 18 lb ft
Crankshaft Bearing Cap Studs (Outer Studs-First Pass in Sequence) 15 lb ft
Crankshaft Bearing Cap Studs (Outer Studs-Final Pass in Sequence) 53 degrees
Crankshaft Oil Deflector Nuts 18 lb ft
Crankshaft Position Sensor Bolt 18 lb ft
Cylinder Head Bolts (First Pass all M11 Bolts in Sequence) 22 lb ft
Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence) 90 degrees
Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head) 90 degrees
Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence) 50 degrees
Cylinder Head Bolts (M8 Inner Bolts in Sequence) 22 lb ft
Cylinder Head Coolant Plug 15 lb ft
Cylinder Head Core Hole Plug 15 lb ft
Drive Belt Idler Pulley Bolt 37 lb ft
Drive Belt Tensioner Bolts 37 lb ft
Engine Block Coolant Drain Plugs 44 lb ft
Engine Block Heater 30 lb ft
Engine Block Oil Gallery Plugs 44 lb ft
Engine Coolant Air Bleed Pipe Bolts and Studs 106 lb in
Engine Crossmember Bolts (Large) 107 lb ft
Engine Crossmember Bolts (Small) 92 lb ft
Engine Flywheel Bolts (First Pass) 15 lb ft
Engine Flywheel Bolts (Second Pass) 37 lb ft
Engine Flywheel Bolts (Final Pass) 74 lb ft
Engine Flywheel-to-Torque Converter Bolts 44 lb ft
Engine Front Cover Bolts 18 lb ft
Engine Mount Heat Shield Nuts 89 lb in
Engine Mount Stud-to-Engine Block 37 lb ft
Engine Mount Through Bolts 70 lb ft
Engine Mount Through Bolt Nuts 59 lb ft
Engine Mount-to-Engine Block Bolts 37 lb ft
Engine Rear Cover Bolts 18 lb ft
Engine Service Lift Bracket M10 Bolts 37 lb ft
Engine Service Lift Bracket M8 Bolt 18 lb ft
Engine Valley Cover Bolts 18 lb ft
Engine Wire Harness Clip Bolt 37 lb ft
Engine Wire Harness Ground Strap Bolt 37 lb ft
Exhaust Gas Recirculation (EGR) Valve Bolts (First Pass) 89 lb in
EGR Valve Bolts (Final Pass) 22 lb ft
EGR Valve Pipe-to-Cylinder Head Bolts 37 lb ft
EGR Valve Pipe-to-Exhaust Manifold Bolts 22 lb ft
EGR Valve Pipe-to-Intake Manifold Bolt 89 lb in
Exhaust Manifold Bolts (First Pass) 11 lb ft
Exhaust Manifold Bolts (Final Pass) 18 lb ft
Exhaust Manifold Heat Shield Bolts 80 lb in
Exhaust Manifold Pipe Nuts 26 lb ft
Front Shock-to-Engine Crossmember Bolts 48 lb ft
Fuel Injection Fuel Rail Bolts 89 lb in
Generator Bracket Bolts 37 lb ft
Generator Rear Bracket-to-Engine Block Bolt 18 lb ft
Generator Rear Bracket-to-Generator Bolt 18 lb ft
Ground Strap Bolt (at Rear of Cylinder Head) 37 lb ft
Ignition Coil-to-Bracket Bolts 106 lb in
Ignition Coil Bracket-to-Valve Rocker Arm Cover Bolts 106 lb in
Intake Manifold Bolts (First Pass in Sequence) 44 lb in
Intake Manifold Bolts (Final Pass in Sequence) 89 lb in
Knock Sensors 15 lb ft
Oil Filter 22 lb ft
Oil Filter Fitting 40 lb ft
Oil Level Indicator Tube Bolt 18 lb ft
Oil Level Sensor 115 lb in
Oil Pan Baffle Bolts 106 lb in
Oil Pan Closeout Cover Bolt (Left Side) 106 lb in
Oil Pan Closeout Cover Bolt (Right Side) 106 lb in
Oil Pan Cover Bolts 106 lb in
Oil Pan Drain Plug 18 lb ft
Oil Pan M8 Bolts (Oil Pan-to-Engine Block and Oil Pan-to-Front Cover) 18 lb ft
Oil Pan M6 Bolts (Oil Pan-to-Rear Cover) 106 lb in
Oil Pressure Sensor 15 lb ft
Oil Pump-to-Engine Block Bolts 18 lb ft
Oil Pump Cover Bolts 106 lb in
Oil Pump Relief Valve Plug 106 lb in
Oil Pump Screen Nuts 18 lb ft
Oil Pump Screen-to-Oil Pump Bolt 106 lb in
Oxygen Sensor 31 lb ft
Positive Crankcase Ventilation (PCV) System Strap Nut (at Right Front Vapor Vent Pipe Stud) 106 lb in
Power Steering Pump Bolts 18 lb ft
Power Steering Pump Bracket Bolts 18 lb ft
Spark Plugs (Cylinder Heads-New) 15 lb ft
Spark Plugs (all Subsequent Installations) 11 lb ft
Throttle Body Bolts 106 lb in
Transmission Housing Bolt 37 lb ft
Valve Lifter Guide Bolts 106 lb in
Valve Rocker Arm Bolts 22 lb ft
Water Inlet Housing Bolts 11 lb ft
Water Pump Bolts (First Pass) 11 lb ft
Water Pump Bolts (Final Pass) 22 lb ft
Water Pump Cover Bolts 11 lb ft
T-56 Transmission Torque Specs
Application Spec
Backup Lamp Switch 20 lb ft
Clutch Actuator Cylinder Bolt 71 lb in
Clutch Housing Bolt 37 lb ft
Control Lever Handle Bolt 18 lb ft
Gear Select/Skip Shift Solenoid 30 lb ft
Reverse Lockout Assembly Bolt 13 lb ft
Reverse Lockout Solenoid 30 lb ft
Shift Control Bolt 13 lb ft
Shift Control Closeout Boot Bolt 18 lb in
Shift Control Knob 27 lb ft
Transmission Bolt 37 lb ft
Transmission Drain/Fill Plug 20 lb ft
Transmission Mount Bolt 38 lb ft
Transmission Mount Nut 77 lb ft
Transmission Support Bolt 66 lb ft
Vehicle Speed Sensor Bolt 89 lb in
