Old 12-18-2009, 03:05 PM   #1
Patsfan34
Patsfan34's Avatar
292 to 350 engine swap...Do I need to replace crossmember
I originally had this posted in the 4x4 section but only had 2 responses so I'm looking for a little more input.
I started breaking down my chassis, it's a 68 GMC 4x4 SWB that I'm turning into a 70 Chevy 4x4 SWB. The current engine is getting yanked out but while I was pulling drive shafts and shocks and other stuff, I noticed the motor mounts on the 292 have stands and all kinds of stuff. Once I yank this engine, I can just buy 350 motor mounts and be done right or no? Also, with the 292 to 350 swap will the placement of the tranny and t/case stay in the same place?
Further, if I do need to change crossmembers can I use the one that's on the 2wd SWB frame now and switch it to my 4x4 SWB chassis?
Happy Holidays,
Patsy!
Patsfan34 is offline   Reply With Quote
Old 12-18-2009, 03:27 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: 292 to 350 engine swap...Do I need to replace crossmember
2x4s and 4x4s are both different animals. You won't be able to use any of the 2x4 crossmember parts on the 4x4 chassis. The 292 uses a different frame mounts than the v-8 does. The short of it is if you are useing a 4x4 chassis, and v-8 engine then you need the v-8 engine crossmember for a 4x4 and not a 2x4. I believe that the rubber motor mounts are the same though. Hope this helps. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-18-2009, 03:38 PM   #3
71 super
71 super's Avatar
On a positive note, the 292 stuff seems to be desirable so you should be able to recoup money to buy the v8 stuff. I would check with billsbowties he parted a couple of blazers recently and may have the crossmember you need. Harold
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 12-18-2009, 06:03 PM   #4
Patsfan34
Patsfan34's Avatar
Now I'm catching on! Looks like I better start shopping for a 4x4 SWB small block crossmember. Thanks everyone!
Old 12-18-2009, 06:07 PM   #5
Classic Heartbeat
Any 4x4 V-8 engine crossmember will do from 67-72. They are all the same, 1/2 ton, 3/4 ton, Blazer, Jimmy, Suburban, Panel. long bed, or short bed. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 12-18-2009, 07:46 PM   #6
Patsfan34
Patsfan34's Avatar
Awesome thanks Wes!
