12-19-2009, 02:08 PM | #1 |
changing door locks
Is it hard to change the door locks on our trucks? My son is having difficulty unlocking both of his doors. They are relatively cheap, but I just want to make sure its a fairly easy repair. Thanks!!
12-19-2009, 02:15 PM | #2 |
Re: changing door locks
It isn't fun but it isn't hard either. You have to pull the inside door panel off and there will be a spring clip on the back side of the door lock. Pull the clip off, swap locks, push clip back on and hook up linkage.
12-19-2009, 02:24 PM | #3 |
Redefining LowBudget
pull the door locks out spray the hell out of them with PB blaster and work them...lube up the lock parts since you have the door panel off I like to use white grease or motorcycle chain lube...put them back in and then your door keys will match your ing..
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
12-19-2009, 02:52 PM | #4 |
it's even cheaper to lubricate the moving parts to make them work smoother
12-19-2009, 05:03 PM | #5 |
I took mine apart cleaned and lubed them and they work great. It's not that hard just keep track of all the clips.
I'm not as good as I once was, But I'm as good once as I ever was. |
12-19-2009, 05:28 PM | #6 |
You should use graphite in door locks as it doesn't attract dirt and dust and won't get stiff in cold weather.
69 Chevy 4x4 383 Power |
12-19-2009, 05:56 PM | #7 |
difficult to do = no
takes awhile to do = yes I would try graphite in them first... If your doors are sagging or if rust has taken hold in the A pillar, B pillar or in the door itself - the locks may never work right...just a heads up. |
12-19-2009, 06:40 PM | #8 |
Its a Truck Thing......
I always change mine out in sets,,,Doors,Ignition,Glove box door, so I only have 1 key to deal with....Simple though, except the ignition sometimes can be a pain.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
12-19-2009, 06:59 PM | #9 |
Like mr48chevsaid, it's no sweat.
When I got my 67 I didn't have the door keys to the locks,so I stripped the door locks from my wrecked 87 S10,and installed them in my 67 doors.They fit perfectly
Doin it one piece at a time. Last edited by smallwin67; 12-19-2009 at 07:07 PM. |
12-19-2009, 11:56 PM | #10 |
The Older Generation
If you roll down the window you can spray the back of the lock cylinders and the mechanism down through the back of the window opening. Then stick the nozzle into the lock and spray it good. Wipe any spray off of the paint with a paper towel. Let it set for a few minutes and work the key in and out and back and forth. If they don't loosen up after doing this a couple of times, replace them. I do not recommend graphite. It is a good lubricant but I have taken lock cylinders apart that have had graphite used on them and when it gets wet it turns into a gummy mess... Just my 2¢ worth. LockDoc
12-20-2009, 07:31 PM | #11 |
GM ONLY BABY!!!
Lubricating locks and hinges is just part of my yearly maintanence on all my vehicles.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
