Old 12-20-2009, 05:37 PM   #1
jnesto
66 c 10 rearend
I have a 66 c10 and want to change the stock rear end on it. I was wondering if any body knows what pick a part rear end would bolt right up. I'm changing it to 5 lug like the front. i really need the help Thank You.
jnesto is offline   Reply With Quote
Old 12-20-2009, 07:40 PM   #2
62gmc910
62gmc910's Avatar
Re: 66 c 10 rearend
the only bolt up replacement is from a 71 or72 disc brake chev 10 The73-80s had the same diff maybe a bit wider,but you have to cut the spring pads off and weld the trailing arm pads on.
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-20-2009, 08:09 PM   #3
Envy
Envy's Avatar
Re: 66 c 10 rearend
I put a 5 lug 12 bolt posi rear out of a 67-72 body truck (dont know what year exactly it was out of) but it bolts right up to my 65, and im using a race car style disc brake set up.
Envy is offline   Reply With Quote
Old 12-20-2009, 09:40 PM   #4
Bugeyev8
Bugeyev8's Avatar
Re: 66 c 10 rearend
I have a 12 bolt in my 62 fron a 77 Chevy C10, works fine no tire rubbing, had to remove the perches and the panhard brackets from my old rear end, been in there for 17 years
Bugeyev8 is offline   Reply With Quote
