Old 12-21-2009, 06:49 PM   #1
timcrow00
slow drain on the battery
so far i have used a volt meter between negative battery post and negative battery cable, and even with everything unplugged from the fuse box there is still current between the two. is there any other systems that dont go through the fuse box? or any other ideals?
timcrow00 is offline   Reply With Quote
Old 12-21-2009, 08:32 PM   #2
78-5.3
78-5.3's Avatar
Re: slow drain on the battery
i have the same problem slow drain even with every fused pulled
78-5.3 is offline   Reply With Quote
Old 12-21-2009, 08:35 PM   #3
72lb4x4
Connecting a voltmeter between a battery cable and post won't give you meaningful info. You want to connect an ammeter or test light that way.
72lb4x4 is offline   Reply With Quote
Old 12-21-2009, 08:39 PM   #4
3r!c84
Badass
3r!c84's Avatar
is your clock pluged in and working
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-21-2009, 08:45 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
or do you have a memory radio with electronic presets/ clock?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-22-2009, 12:46 AM   #6
timcrow00
ive dont have a clock except on the radio and i unhooked that before doin anything and ive tried the test light with the same results
Old 12-22-2009, 11:47 AM   #7
grinch4om
dang its hot
grinch4om's Avatar
pull the dome bulb in the ceiling out and recheck...I had a door switch fail and dimly lit the dome bulb...granted, I don't drive mine for a week at a time but battery would be dead
grinch4om is offline   Reply With Quote
Old 12-22-2009, 03:49 PM   #8
timcrow00
ill try that it does take atleast a week or more for it to drain the battery all the way
Old 12-22-2009, 05:39 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
try taking out a fuse at a time.....and wait
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
