![]() Join Date: Jun 2002
Drive shaft and trailing arm question
First of all, how do you replace the bushings on the trailing arms? They are out of the truck. Secondly, how do you take the drive shaft apart at the carrier bearing?
Re: Drive shaft and trailing arm question
I used a ball joint press to change out the bushings and for the drive shaft remove the ujoint and remove the bolt that's in the center of the shaft.
I used a torch to remove my trailing arm bushings. Which carrier bearing do you have?
![]() Join Date: Jan 2006
first off if you live near an autozone take advandage of their tool lending program. Follow this link for overhaul of driveshaft. http://67-72chevytrucks.com/vboard/s...d.php?t=171772 I don't know why the pictures don't show up anymore, but at least you can read through it....shame though because it was a very informative write up with great photos on driveshaft overhaul...maybe something the admins can fix......Rick
69 C10 LWB GM 350 crate motor, 3.73 rearend
Wish it had pic too. I need to replace my carrier bearing. Any one have a part number for the carrier bearing for a 2 piece drive shaft?
1970 GMC truck ![]() 1988 Harley 1200 Sportster
| Bookmarks |
| Tags |
| driveshaft, trailing arms |
| Thread Tools | |
| Display Modes | |
