Old 12-22-2009, 06:57 PM   #1
layingC10nK5
Z frame and PB dropmember???
ok im getting ready to start my air suspension on my 68 swb. the previous owner started a Z on the frame, its just spotwelded not complete. he did about two inches and i was wondering if i can complete the 2 inch Z and then install a dropmember. i want the narrow track with and the centered wheel the DM provides. i have owned the truck for about 3 years and purchased an Ls1 last week for it so the frame needs to get done. i plan on running 24in wheels all around and want it as low as possible. thanks for all input.
layingC10nK5 is offline   Reply With Quote
Old 12-22-2009, 07:30 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Z frame and PB dropmember???
There was one other truck done(started?) this way. I think you'll at least have to run stock spindles, though I dunno w/ fours- depends on tire size... Depending on where the cuts were made, everything should line up. You will have cab/trans clearance problems for sure..
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is online now   Reply With Quote
Old 12-22-2009, 08:43 PM   #3
kev2809
low n' slo
kev2809's Avatar
why dont you cut it back off and weld it back to stock?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-23-2009, 03:56 AM   #4
OARNGESI
OARNGESI's Avatar
CHECK OUT THIS THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=258916
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 12-23-2009, 03:58 PM   #5
layingC10nK5
thaks for the input guys. the reason for not re-welding it back to stock is i figure i will be able to run 24's and still get damm close to the ground. i understand the hood will be an issue but unless i find or u guys tell me of any other major issues i want to give the 24,s a try. what are any disadvantages mof running stock vs drop spindles?? thanks guys.... pics coming soon
Old 12-23-2009, 04:12 PM   #6
OARNGESI
OARNGESI's Avatar
Will you get enough lift to turn only thing i can think of
70 SWB STEPSIDE
70 BLAZER
09 challenger
