Old 04-24-2003, 09:29 AM   #1
Zilverado
Zilverado's Avatar
Question Exhaust Pipe Sealant???
So, is there a sealant that can be used on flanged exhaust pipe connections? If so how well does it work and how easy is it to remove in the future?
The Situation:
I have a 2-bolt flanged connection that I noticed was leaking (and noisy). The gasket is the grey "asbestos" type with a wire braided reinforced core. I bought the gasket, new bolts and put it all back together. It still leaks slightly, so it likely won't take long to burn up the gasket. It seems as if the flanges are possibly slightly warped. The connection is tight at the bolts, but appears to be slightly open at the "fat" part (around the pipe). This is where the leak is.
So, back to the sealant question. Is this an option, or should I try to go with a double gasket to try and fill the space? I was thinking of using sealant together with the gasket.
What do y'all think?
Zilverado is offline   Reply With Quote
Old 04-24-2003, 10:23 AM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
Why yes of course there is Sir! It' be called Mig-glue by the way
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 04-24-2003, 11:10 AM   #3
BigRed
I don't know of any sealant for flanges. Most of the exhaust shops that I've talked to say that if they have consistent problems with leaky flanges that they just weld them. Don't know if you really want to do that, but it's an option.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 04-24-2003, 11:19 AM   #4
Zilverado
Zilverado's Avatar
Thanks for the info Guys.
I just spoke to a local auto parts place and they said they have some stuff that is used for this application. Might have to give it a try - I was just concerned about having a messy job if I ever have to replace the gasket in the future.
Bigred
As far as welding the flanges goes, I've thought of that. Certainly would solve the problem (for now). Two problems with this though - I'd have to drop the pipe to get a good all around weld (big job) and it would be impossible to separate this joint in the future.
So that's it. Thanks again and keep the suggestions/experiences coming.
Old 04-24-2003, 12:32 PM   #5
BigRed
Yeah, I had the same problem with the old exhaust system on my truck. They had cut the flanges off and just welded the pipe together. I had to use a radiac to get the freaking headers off! But, no leaks.
Scott Shelbourne
