Old 12-23-2009, 08:24 PM   #1
project 67 sub
project 67 sub's Avatar
Question coil rear suspension.......
can bolts be used in place of u-bolts if so what kind? good idea or bad and why?
project 67 sub is offline   Reply With Quote
Old 12-23-2009, 09:11 PM   #2
kev2809
low n' slo
kev2809's Avatar
Re: coil rear suspension.......
if u take out the u bolt, and use a bolt, what will hold the axle down?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-23-2009, 09:17 PM   #3
Super73
Super73's Avatar
Not with out some fabrication..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 12-23-2009, 10:50 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Don't do it.
I saw a nice truck destroyed years ago, because a guy did the same thing.
(rearend came out from under the truck at 55mph on a corner)
Get the proper u-bolts!
Old 12-23-2009, 11:55 PM   #5
project 67 sub
i have the proper u bolts in it now i was just thinking cause i think they might end up hitting my notch and not allow it to fully lay out.
Old 12-24-2009, 12:38 AM   #6
kev2809
low n' slo
kev2809's Avatar
can u cut like an inch off the bottom of the notch or whatevery u need then plate it back up?
-_--_--_ _________
Old 12-24-2009, 01:54 AM   #7
2tons of fun
the bolts would still tighten the the pad down which is welded to the rear. if you dont make a lot of hp, hydro jump, or do high speed driving i would say do it.
however, you would be safer to trim more of your framework to make it clear and keep the u bolt.
2tons of fun is offline   Reply With Quote
Old 12-24-2009, 11:12 AM   #8
Tony@AirRideTech
Junior Member
I dont think I would guess for a 1/2"
Tony@AirRideTech is offline   Reply With Quote
