Old 12-27-2009, 11:49 PM   #1
AJLChase
AJLChase's Avatar
Bed bolt removal
Any tips on the best way to get the bolts to stop spinning when you unloosen the nuts? Or, what to use to just simply remove the bolt and nut from the equation? Thanks!
AJLChase is offline   Reply With Quote
Old 12-28-2009, 12:00 AM   #2
DZL1
One day.....
DZL1's Avatar
Re: Bed bolt removal
With a grinder cut a groove on the head of the bolt. To make it look like a slotted screw. Then with someones help and a flat head screwdriver, ask them to hold the "screw" you just made, while you get under the truck and loosen the nut. Hope this helps.
DZL1.
DZL1 is offline   Reply With Quote
Old 12-28-2009, 12:03 AM   #3
fishingjred73
fishingjred73's Avatar
Tack weld nuts on them easier to hold than the screwdriver or use the good old cuttin torch.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 12-28-2009, 12:05 AM   #4
red69ss
Burnouts are therapeutic
red69ss's Avatar
drill the heads out ,don't even try to loosen them
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 12-28-2009, 12:54 AM   #5
chipflyer
chipflyer's Avatar
Get your impact out (I can do it with my long handle ratchet) and TIGHTEN them, yes I said TIGHTEN them. They will easily break off. much easier and quicker than the other options and you were going to have to replace them anyway.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 12-28-2009, 08:03 AM   #6
cdowns
cdowns's Avatar
i've always just ground the heads off wilh a cutoff wheel soas to not mess up the square mounting holes in the bed floor
Old 12-28-2009, 08:21 AM   #7
lakeroadster
Jeff
Amen brother! If the bed wood is rotted and the bolt is loose use vice grips. The tighten until the bolt shank twists in two.
lakeroadster is offline   Reply With Quote
Old 12-28-2009, 01:47 PM   #8
Strut
Strut's Avatar
I tighted them down and used a wire brush on a air tool to remove most of the rust. Then Impact to take them off. I had to cut slots on a few bolts. Took the whole bed apart only broke 3 bolts......
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 12-28-2009, 01:51 PM   #9
tcb-1
Nothing to see here.....
tcb-1's Avatar
I drilled mine out from inside the bed, then whacked them out from the top. easy as pie.....
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
