12-29-2009, 02:54 PM | #1 |
tubbing the 69
Anyone ever tub their 67-72 chevy truck pics and measurements would be helpful thanks !
12-29-2009, 03:07 PM | #2 |
Re: tubbing the 69
are you going to cut on the frame and tub or just take out of the bed?
I just cut my bed out and I'm leaving the frame stock. I have trailing arms and my plan is to get the biggest tire in there possible. I am trying for a 31x18x20???? I asked this question a few times for tire sizes and mostly just got he answer measure and fit! here is a pic of how much I cut out of the bed: |
12-29-2009, 03:51 PM | #3 |
Re: tubbing the 69
Are you going to be useing a 4 link or ladder bar set up? Theres not going to be any real set measurments due to eveyone almost runs a different lenght setup on there rear end. I have done about 5 tubb jobs but not on a full size truck, only a s10, camaro, vega and a monza, el camino, mustang. I find its always best for me to start with the tire and work from there. Next get the offset of the rim you want, then build the lenght in the rearend and then set up the suspension and brakes.
I have started the tub job my 68 GMC swb, but now I have decided against it. I already had the narrowed rear end from another project but I couldnt find the rims that I wanted to use. I was going to have to run some 15x15 Weld (draglites) wheels, and Im just tired of that look. Now if I could find some affordable 17" or 18" or even bigger torque thruster style rims that are 14" or 15" wide with a 3 inch backspace I would do it. Now Im just going to find another rearend that I can use and run a 18x10 or 18x11 rim on. |
12-29-2009, 04:00 PM | #4 | |
Re: tubbing the 69
Stock truck arm set-ups w/the short housing (6x-69's & early 70's) can get a 18.5 on a 15" wheel using an un-narrowed housing & the right back-spacing. The bumpstop brackets need to be removed & the e-brake cables routed (or eliminated) so they don't interfere.
12-29-2009, 05:01 PM | #5 | |
Re: tubbing the 69
12-29-2009, 08:03 PM | #6 |
Re: tubbing the 69
thanks for the replys i was thinking about cutting the frame and the bed both and shorting the rear end and eventually runing a 4 link system
03-07-2011, 10:01 AM | #7 |
Re: tubbing the 69
hey man there is a guy on here just look up "my sorta build thread" in the search box and he gives excellent detail the tire size and everything... he fit 31x18.5 on her
