12-29-2009, 03:06 PM | #1 |
87 1-ton 4x4. What year frames are the same?
I've got an 87 1-ton 4x4 GMC. Eventually, some day, after I become independently wealthy and get my other 5,000 projects done, I'd like to freshen up my truck. My current frame has a significant amount of rust and scale on it, and I'd rather have something cleaner to start with when I do actually start a resto. Plus by having a spare frame, I can do a significant amount of work before I actually take my truck out of commission.
So anyway... enough babble... what other model year frames will work with no/minimal modification? |
12-29-2009, 03:16 PM | #2 |
3/4 Ton Rodder
Re: 87 1-ton 4x4. What year frames are the same?
I think any 73-87 3/4-1 ton 4x4 frame will work.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
12-29-2009, 03:54 PM | #3 |
Extended cab fanatic
73-80 have different body mounts, than the 81-87. Not a problem, just use the correct body mounts for the year of the frame
If it has a motor, it has my attention. |
12-29-2009, 05:11 PM | #4 |
Good to know. I didn't realize the frames stayed the same through the entire run. Hopefully I can find a decent southern 4x4 utility truck for not much money so I can use the frame.
12-29-2009, 06:00 PM | #5 |
Still plays with trucks
I thought the 1-ton frames were taller than the 3/4-ton frames or was this just the dually 1-ton frames?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
12-29-2009, 08:23 PM | #6 |
1 ton frames are taller, 2wd/4wd doesn't matter. Look for an old military truck that someone robbed the axles out of.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
12-29-2009, 09:42 PM | #7 |
At the body shop.
3/4 tons are taller that 1/2 tons also
" That didnt make it any newer " " Dont antique the equipment " |
12-29-2009, 09:58 PM | #8 |
Frames are the same, might be a wee bit thicker, but the same height. Have more springs to make it sit higher.
12-30-2009, 01:01 PM | #9 |
on what, the 1/2 to 3/4 tons, or all of them? I was told that the 1 ton frames were 2" taller than the 1/2 and 3/4 ton frames, so I had to get the frame from a 1 ton truck.
Now, somebody said 2wd/4wd doesn't matter... really? I thought the frames were different in the front where the suspension components mounted? It would be great if I could use a 2wd frame because I'd expect those to be a lot more common in the rust-free states. Last edited by Jim85IROC; 12-30-2009 at 01:03 PM. |
12-30-2009, 01:07 PM | #10 |
Somebody just posted the thicknesses but I don't remember the exact numbers. It was about 0.18" for the 1/2-ton frame and 0.23 for the 3/4-ton.
12-30-2009, 04:16 PM | #11 |
Dually Pride
1 ton frames are DEFINATLY taller than 1/2 and 3/4 tons. on a 2wd, suspension is mounted to the engine crossmember, so 2wd/4wd is interchangeable
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
12-30-2009, 08:28 PM | #12 |
The 1/2 and 3/4 ton frames are the same height, but 3/4t are thicker. 1 ton frames are taller than 1/2 and 3/4, regardless of 2wd or 4wd.
The frames are similar between 2wd/4wd, I found out that the 4wd crossmember won't go in a 2wd frame. That is biggest thing holding me up to getting my crew done. Had a 1/2, 3/4 and 1 ton frame to compare, they were all the same.
12-30-2009, 09:47 PM | #13 |
Junior Member
"The frames are similar between 2wd/4wd, I found out that the 4wd crossmember won't go in a 2wd frame."
Is this between 1 ton frames? I am pretty much in the same boat then! I have a 4wd dually and need to rebody,thought I would just take all the 4wd stuff off. I didnt want to break up the integrity of a cherry 2wd dually. Last edited by scotto0609; 12-30-2009 at 09:48 PM. |
12-30-2009, 09:55 PM | #14 |
I had a crossmember from a 1/2-3/4 ton that I tried in my 1 ton 2wd frame, didn't fit. Also had a parts 1 ton 4wd, measured it inside of frame, same thing as the 1/2-3/4 ton. It's not much, 1/4" I think, but don't have a welder to fix it. I'm gonna try and use the stock 2wd mounts, just need to make a crossmember to tie the frame together. But really need to have the motor in there, being it's a tall deck with the huge pan, need to make sure there is room for movement, dropping the pan, etc.
12-30-2009, 11:09 PM | #15 |
At the body shop.
THis pic is of 3/4 ton trans Xmember In a 1/2 ton frame (mine) see the notch cut so the trans wont hit the floor. I used it to make more room for exhaust I will measure tommorow for numbers but maybe keith can shed some light
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 12-30-2009 at 11:11 PM. |
12-31-2009, 02:08 AM | #16 |
Is this why the 1ton sits a little taller?
12-31-2009, 08:59 AM | #17 |
But were talking engine crossmembers.
1 tons sit taller because the frame is roughly 2" taller. Beefy springs help too.
12-31-2009, 02:44 PM | #18 |
At the body shop.
My bad youre right B454 engine x memeber is the same
12-31-2009, 04:28 PM | #19 |
Next!
From the 1987 GM Chevy Truck Facts Book, has every spec on every model for frames.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
01-01-2010, 01:04 AM | #20 | |
The bumper mounts right to the frame in earlier ones and the later ones have brackets that mount to the bumper. Last edited by BurnoutNova; 01-01-2010 at 01:04 AM. |
01-01-2010, 02:15 AM | #21 |
I have major rust problems on my 4x4 1 ton dually also. Just wandering if it would be cost prohibitive to have the frame reworked?
01-01-2010, 09:27 AM | #22 |
Next!
do a frame swap. Find a CUCV M1008 or M1028 that some one bought just for the rears and you have a good frame to work with, There's a thread on here somewhere of the frame swap I did on my 83 k30 dually using a M1010 ambulance frame. ( I got the whole "what was left of the truck" for $200.00)
01-01-2010, 12:51 PM | #23 |
How do I break down the frame chart so I can understand it?
01-01-2010, 01:52 PM | #24 |
Next!
C equals 2 wheel drive
K equals 4 wheel drive P is P forward control chassis S is S10 pickup 10903 20903 30903 are 8'0" pickups 20943 30943 are 4 door pickups 31003 is a cab chassis and so on
01-01-2010, 05:10 PM | #25 |
Thank you very much!
