Old 12-29-2009, 03:06 PM   #1
Jim85IROC
Jim85IROC's Avatar
87 1-ton 4x4. What year frames are the same?
I've got an 87 1-ton 4x4 GMC. Eventually, some day, after I become independently wealthy and get my other 5,000 projects done, I'd like to freshen up my truck. My current frame has a significant amount of rust and scale on it, and I'd rather have something cleaner to start with when I do actually start a resto. Plus by having a spare frame, I can do a significant amount of work before I actually take my truck out of commission.
So anyway... enough babble... what other model year frames will work with no/minimal modification?
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 12-29-2009, 03:16 PM   #2
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
Re: 87 1-ton 4x4. What year frames are the same?
I think any 73-87 3/4-1 ton 4x4 frame will work.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 12-29-2009, 03:54 PM   #3
rare86
Extended cab fanatic
rare86's Avatar
73-80 have different body mounts, than the 81-87. Not a problem, just use the correct body mounts for the year of the frame
If it has a motor, it has my attention.
rare86 is offline   Reply With Quote
Old 12-29-2009, 05:11 PM   #4
Jim85IROC
Jim85IROC's Avatar
Good to know. I didn't realize the frames stayed the same through the entire run. Hopefully I can find a decent southern 4x4 utility truck for not much money so I can use the frame.
454
TH400
My Sounddomain Page
Old 12-29-2009, 06:00 PM   #5
68 TT
Still plays with trucks
68 TT's Avatar
I thought the 1-ton frames were taller than the 3/4-ton frames or was this just the dually 1-ton frames?
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 12-29-2009, 08:23 PM   #6
b454rat
1 ton frames are taller, 2wd/4wd doesn't matter. Look for an old military truck that someone robbed the axles out of.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-29-2009, 09:42 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
3/4 tons are taller that 1/2 tons also
Old 12-29-2009, 09:58 PM   #8
b454rat
Frames are the same, might be a wee bit thicker, but the same height. Have more springs to make it sit higher.
Old 12-30-2009, 01:01 PM   #9
Jim85IROC
Jim85IROC's Avatar
on what, the 1/2 to 3/4 tons, or all of them? I was told that the 1 ton frames were 2" taller than the 1/2 and 3/4 ton frames, so I had to get the frame from a 1 ton truck.
Now, somebody said 2wd/4wd doesn't matter... really? I thought the frames were different in the front where the suspension components mounted? It would be great if I could use a 2wd frame because I'd expect those to be a lot more common in the rust-free states.
454
TH400
My Sounddomain Page
Old 12-30-2009, 01:07 PM   #10
68 TT
68 TT's Avatar
Somebody just posted the thicknesses but I don't remember the exact numbers. It was about 0.18" for the 1/2-ton frame and 0.23 for the 3/4-ton.
Old 12-30-2009, 04:16 PM   #11
74 C-30
Dually Pride
74 C-30's Avatar
1 ton frames are DEFINATLY taller than 1/2 and 3/4 tons. on a 2wd, suspension is mounted to the engine crossmember, so 2wd/4wd is interchangeable
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 12-30-2009, 08:28 PM   #12
b454rat
The 1/2 and 3/4 ton frames are the same height, but 3/4t are thicker. 1 ton frames are taller than 1/2 and 3/4, regardless of 2wd or 4wd.
The frames are similar between 2wd/4wd, I found out that the 4wd crossmember won't go in a 2wd frame. That is biggest thing holding me up to getting my crew done. Had a 1/2, 3/4 and 1 ton frame to compare, they were all the same.
Old 12-30-2009, 09:47 PM   #13
scotto0609
Junior Member
"The frames are similar between 2wd/4wd, I found out that the 4wd crossmember won't go in a 2wd frame."
Is this between 1 ton frames? I am pretty much in the same boat then! I have a 4wd dually and need to rebody,thought I would just take all the 4wd stuff off. I didnt want to break up the integrity of a cherry 2wd dually.
scotto0609 is offline   Reply With Quote
Old 12-30-2009, 09:55 PM   #14
b454rat
I had a crossmember from a 1/2-3/4 ton that I tried in my 1 ton 2wd frame, didn't fit. Also had a parts 1 ton 4wd, measured it inside of frame, same thing as the 1/2-3/4 ton. It's not much, 1/4" I think, but don't have a welder to fix it. I'm gonna try and use the stock 2wd mounts, just need to make a crossmember to tie the frame together. But really need to have the motor in there, being it's a tall deck with the huge pan, need to make sure there is room for movement, dropping the pan, etc.
Old 12-30-2009, 11:09 PM   #15
KQQL IT
At the body shop.
KQQL IT's Avatar
THis pic is of 3/4 ton trans Xmember In a 1/2 ton frame (mine) see the notch cut so the trans wont hit the floor. I used it to make more room for exhaust I will measure tommorow for numbers but maybe keith can shed some light
Old 12-31-2009, 02:08 AM   #16
SMiller
Is this why the 1ton sits a little taller?
SMiller is offline   Reply With Quote
Old 12-31-2009, 08:59 AM   #17
b454rat
But were talking engine crossmembers.
1 tons sit taller because the frame is roughly 2" taller. Beefy springs help too.
Old 12-31-2009, 02:44 PM   #18
KQQL IT
At the body shop.
KQQL IT's Avatar
My bad youre right B454 engine x memeber is the same
Old 12-31-2009, 04:28 PM   #19
GM72K10
Next!
GM72K10's Avatar
From the 1987 GM Chevy Truck Facts Book, has every spec on every model for frames.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 01-01-2010, 01:04 AM   #20
BurnoutNova
BurnoutNova's Avatar
The front of the frame (frame horns) is diffrent too between 73-80 and 81-87/91
The bumper mounts right to the frame in earlier ones and the later ones have brackets that mount to the bumper.
BurnoutNova is offline   Reply With Quote
Old 01-01-2010, 02:15 AM   #21
oldwagon
oldwagon's Avatar
I have major rust problems on my 4x4 1 ton dually also. Just wandering if it would be cost prohibitive to have the frame reworked?
oldwagon is offline   Reply With Quote
Old 01-01-2010, 09:27 AM   #22
GM72K10
Next!
GM72K10's Avatar
do a frame swap. Find a CUCV M1008 or M1028 that some one bought just for the rears and you have a good frame to work with, There's a thread on here somewhere of the frame swap I did on my 83 k30 dually using a M1010 ambulance frame. ( I got the whole "what was left of the truck" for $200.00)
86 K30 CUCV M1028A1
Old 01-01-2010, 12:51 PM   #23
SMiller
How do I break down the frame chart so I can understand it?
Old 01-01-2010, 01:52 PM   #24
GM72K10
Next!
GM72K10's Avatar
C equals 2 wheel drive
K equals 4 wheel drive
P is P forward control chassis
S is S10 pickup
10903 20903 30903 are 8'0" pickups
20943 30943 are 4 door pickups
31003 is a cab chassis
and so on
86 K30 CUCV M1028A1
Old 01-01-2010, 05:10 PM   #25
SMiller
Thank you very much!
