12-29-2009, 10:36 PM | #26 |
Badass
Re: oil from my header
nahh its cold down here in Florida .in the 50s all day (: good day to work on my truck
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
12-29-2009, 10:37 PM | #27 |
lol here in texas it been just about freezeing, had some sleet today and i havent been outside since
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622 |
12-29-2009, 10:41 PM | #28 |
Badass
so what kinda headers do u have? i just put on my hooker longs today not all the way done
12-29-2009, 10:44 PM | #29 |
just some summit headers i was in a rush to get her runnin haha
12-29-2009, 10:46 PM | #31 |
what do you mean? lol i have duals that dump off right before my back tire.
12-29-2009, 10:48 PM | #32 |
Badass
yeah so do i.
like did you have the exhaust done befor you put the headers on and had to redo it?
12-29-2009, 11:04 PM | #33 |
no i did the headers then took it to the exhaust shop
12-29-2009, 11:10 PM | #35 |
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622 Last edited by Silence86; 12-29-2009 at 11:10 PM. |
12-30-2009, 12:54 AM | #36 |
what mufflers do you have?
12-30-2009, 12:37 PM | #38 |
well it sounds like a good time to learn and if you got a unheated garage to work on it your better off then some of us that have to stand out in the freezing rain just to keep our trucks running
Im going out to lay on the frozzen ground to put a starter in and I'm happy
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
12-30-2009, 01:00 PM | #39 |
yeah i dont even have a garge to work in, my dads got his project 64 and his and my moms bikes in
12-30-2009, 01:04 PM | #40 |
Still plays with trucks
I am assuming you have no air compressor so your best bet is to buy a screw type valve spring compressor. It will clamp over the top of the spring & retainer and compress the spring to the point you can remove the locks & retainer so the spring can come off. Something like this:
http://www.summitracing.com/parts/OTC-4573/?image=large You will need to put something into the cylinder to keep the valves from falling into the hole. Compressed air works but assuming you don't have an air compressor you can use nylon ski rope or even an old extension cord shoved in through the spark plug hole. Turn the crank bolt over until the piston stops against the rope then you can pull the valve springs on that cylinder without dropping a valve. Tap the top of the retainer with a rubber mallet before you try to remove the spring. This will break the retainer free of the locks. They get stuck together pretty good sometimes.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
