Old 12-31-2009, 12:46 AM   #1
Baged72
Baged72's Avatar
Hot wire when ignition is on under hood?
Installing an electric fuel pump and i want it to come on when my ignition is on only, is there a wire somewhere under the hood i can splice into or do i have to go into the actual ignition switch?
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Baged72 is offline   Reply With Quote
Old 12-31-2009, 01:17 AM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Hot wire when ignition is on under hood?
Ignition unfused on the fuse box. I'd run a relay though.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-31-2009, 01:17 AM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
ignition unfused in your fusebox....
John
1999 Toyota Tacoma 4x4
Old 12-31-2009, 01:22 AM   #4
Baged72
Baged72's Avatar
Next dumb question where is that fuse box located? im not near my truck and i dont want to spend time looking for it, im in a really big hurry to finish it up. Also what kind of relay do i pick up??
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 12-31-2009, 01:29 AM   #5
dan42
dan42's Avatar
Don't be in a hurry. Do it right. The fuse box is located under the dash on the far left of the driver's side.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 12-31-2009, 01:34 AM   #6
Baged72
Baged72's Avatar
Have to be in a hurry i only have 4 days left to use my shop then everyone is back to work and i need to take my truck out to make room. I remember where the fuse box is located now. What kind of relay do i ask for at the parts store???
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 12-31-2009, 07:57 AM   #7
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
I am useing a Holly Blue electric fuel pump with a Fuel Pump Relay from www.ronfrancis.com Item Number: FP-35 or you can SOLVE TWO PROBLEMS GET YOUR FUEL PUMP RELAY AND ADD SAFETY! with there CRASH RELAY SWITCHES FOR ELECTRIC FUEL PUMPS Item Number: CR-92
Or http://www.summitracing.com/parts/SUM-890023/ has a cheaper one for $24.95 Summit Racing SUM-890023
But I see you are short of time I know AutoZone caries them too and Kragen does too just alittle more expensive like $50bucks
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 12-31-2009, 09:00 AM   #8
Sammy
I found the unfused fusebox spot having too much there already. And used one off the ignition switch. When you start adding HEI, headlight mods, door poppers, electric antenna, electric choke, dual fans, and electric fuel pump among more stuff managing safe places to tap in becomes a challenge.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 12-31-2009, 12:28 PM   #9
Baged72
Baged72's Avatar
I have not looked yet, but i have HEI not sure how the previous owner wired it.
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
