Old 01-02-2010, 04:13 AM   #1
chevy71super
What did I do this year?
I made a number of small changes to my truck this year that I thought I would share. The changes are subtle, fixing things that when I first restored the the truck in 2002 I either made a short cut or enhanced the previous work. Most of you have seen my truck.
I added a master electrical cut off switch on the ground side. This truck sits for months at a time and the battery will eventually draw down. This idea came from the board:
I changed the headlight wiring using a relay and cleaned up the under hood wiring in general. I am mixed on the headlights. They look cool at dusk but they are ill designed made in China crap so I will be looking for alternatives:
I upgraded the stereo adding two 12 inch subs under the seat. They are Kenwood thin design subs driven by a Rockford amp. I still had to raise the seat about an inch to clear the modified boxes I bought:
I was running the truck with a 2.5" all spring lift with 35" BFG Mud's. Obviously a pavement cruiser. To give better clearance I installed ORD zero rate blocks in the rear moving the axle back 1". To keep the truck level I also installed blocks in the front with no offset. I am pleased with the result though 3/4 inch would be perfect IMHO. (The blocks move the axle 1" or 1.5" depending upon which holes you use.) No more rubbing on the rear:
Before the change:
After the change:
I also cleaned up the rear brake lines. I needed new rear brake lines when I restored it but the only pre bent ones available at the time where for 2 wheel drive which route differently across the axle than 4 wheel drive. My original installation was hastily done so I cleaned it up:
Overall I am happy with the way the truck looks:
But there are a number of changes/fixes needed to make it more pleasent to drive. The items I would like to tackle in 2010:
Upgrade brakes
Install a raised steering arm
Radiator/Cooling upgrades
Fix lifter noise
Fix oil leaks
Reroute exhaust
Have a happy and productive new year.
Doug
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 01-02-2010, 10:05 AM   #2
big_al_71
big_al_71's Avatar
Re: What did I do this year?
looks very nice....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-02-2010, 10:15 AM   #3
Sammy
Looks good. I like what you accomplished during the year.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 01-02-2010, 10:17 AM   #4
Sammy
I have been debating on those halo headlights myself. Apparently your not impressed.
Old 01-02-2010, 10:53 AM   #5
chevy72pu
chevy72pu's Avatar
Ahhh! The satisfaction of a job well done. Everybody else may not notice ALL the things you've done to it, but you will know and that is what matters.
How 'Bout them Dawgs!
'10 Traverse LTZ
03 Silverado Z71 ext cab
99 Yamaha Grizzly 600
72 C10 350/350 sportside bed.
68 C30 flatbed. 350 4-speed.
"I've got a good memory, it's just short!"
chevy72pu is offline   Reply With Quote
