67-72 cab on a 79 frame ????
ok will this work and if so what all will it take to make it work
Redefining LowBudget
Re: 67-72 cab on a 79 frame ????
subscribed??
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Enjoying left field
At the very least, the wheelbase is different.
One of my buddie's ex son in laws did one and while it can be done not much fits as is.
He put a two wheel drive body on a 4x4 chassis so it might be a bit easier with a 2x4 but I don't think it will be all that much easier. He did this because my buddy had the late 70's 3/4 ton 4x4 sitting there with a bad body and good chassis. Unless you just don't have a usable chassis I can't see the wisdom of going to all the work to make it fit. It will still be a cobbled together truck. There are easy disk brake or five lug swaps on these trucks that take care of the things that most guys think they need to swap frames for. |
its all about the +6 inches
you'll need a flat frame on a 2 wheel drive, unless you want to do a body lift on a 2 wheel drive.
thanks i was just wondering some told me it was a bolt on deal and others say no so thanks again
no way a bolt on, even a 4X4 would requre adjusting the wheel base and a custom body lift and a whole lotta odds and ends.
SWB 4x4 Collector
![]() Join Date: Jun 2001
You need to take the mouse and click on the search button to get this to work.
![]() It can be done, and I did a long time ago on my first truck in high school, but if you search it, there has been this same topic asked several times each year. I think if we ask Mudder, maybe we could have him make a sticky for this in the 4x4 section. You will need to either make new body mounts or re-use them from your original frame. Also, you will have to cut the frame as the wheelbases are different. Like I said above, contact a member here that goes by "Mudder", he is a great guy. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever Last edited by 71blksuper4x4; 01-02-2010 at 11:48 PM. |
