Old 01-04-2010, 06:51 PM   #1
NicoSlam
Lowered my 69 SWB progress
I had a chance to lower the back of my 69 SWB. I purchased the ECE disc brake 4/6 combo with super trac bar etc. The first pic is the original height and the second is after I dropped it. I was planning on changing the tires but it actually looks good with 31's. What do you think? I am also replacing the painted bumpers with chrome ones. I'll get to do the front this weekend.
NicoSlam is offline   Reply With Quote
Old 01-04-2010, 07:13 PM   #2
72 Super
72 Super's Avatar
Re: Lowered my 69 SWB progress
The rear looks great. I myself like a tall tire on my trucks I usually run the 255's, but the 31's look fine to me. Are you going to lower the front any? I would atleast level it out or a little lower in the front.
I see you bought the kit ooops lol I think it will look great.
That's a great looking truck BTW.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 01-04-2010, 07:14 PM   #3
powell72
powell72's Avatar
Nice clean old truck. Looking good so far. I think you'll be changing out those 31's out of necessity after you drop the front!
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-04-2010, 10:58 PM   #4
big_al_71
big_al_71's Avatar
once you lower the front you will have to get smaller tires at least in the front. It will look terrific once is finished..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-05-2010, 09:40 AM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
with Chris and Al... you will probably have to end up change the front tire size once the front it lowered.
But... so far, the drop is looking real good. Excellent choice on the drop as I don't think you can get a better looking drop than the 4/6". Now, only two pics will not suffice, I/we need more pics!
Love the color combo on your truck as well. IMO, that's one of the best looking colors ever offered by Chevrolet for these trucks. Do you have the matching tailgate?
Nice work so far!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-05-2010, 10:21 AM   #6
NicoSlam
Thank guys. I did find a pair of 15x7 truck ralley wheels in which I'll put in the front to offset the push out the spindles will create ( thanks for the earlier heads up 72BlckButy). Do you think I will still need to replace the 31's if I install the 15x7's up in front? I'm looking for the full look so what other size tire would work good?
Old 01-05-2010, 03:02 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Louis, I'll have to measure my front tires tonight, but I believe you will have to swap the front tires as they will be more likely to bottom out while driving. IMO, a great looking set of tires of a set of 15x7's (f) and 15x8's (r) would be similar to what lolife99 is running on NO-LIFE.
Tire specs are: 215/70-15's and 275/60-15's
Like I mentioned in our previous pm's, I'm currently running 235 75R15's on all four corners (not by choice) and they have done very well. I was alittle concerned with the tire height, but so far, so good.
-Nate
Old 01-05-2010, 05:00 PM   #8
threeonthetree
threeonthetree's Avatar
Looks good.
I just put a pair of those rims and tires on my truck.
im wishing i would have bought a set of 15x8s instead of the ones i got.
but my truck is only lowerd a 3/5
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 01-05-2010, 05:06 PM   #9
JWall
Frequent Flyer
JWall's Avatar
Originally Posted by 72BlckButy View Post
I'll have to measure my front tires.... I'm currently running 235 75R15's
Overall Diameter: 28.87 in
- Justin
1 Owner 1976 SWB
Old 01-06-2010, 09:10 AM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks JWall... I didn't have a chance to pull the measurement last night.
-Nate
Old 01-06-2010, 09:43 AM   #11
JWall
Frequent Flyer
JWall's Avatar
No problem. I actually had it written in a notebook at my desk here at work, when you told me your tire size previous I looked it up to compare it to mine in hopes they clear when I get my drop done. (which should be in the next 2 weeks when the weather clears up a little more )
- Justin
1 Owner 1976 SWB
Old 01-06-2010, 09:59 AM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I was just about to pm you and check on your install. We hope to see a similar thread started by you in the near future...
-Nate
Old 01-11-2010, 01:50 PM   #13
NicoSlam
Update: Lowered my 69 SWB progress
I had the chance to complete the 4/6 drop on the truck. The front kit was fun to install considering I had to use a fork and a sledge hammer to release one of the ball joints. I'm also curious why ECE simply supplied a 1/4" to 3/16" adapter for the front brake lines instead of supplying a brake line and having to reshape. Had a tuff time removing the brass tee fitting as well. I installed 15x7's in the front. The 31's do not rub nor bottom out and do a good job in filling in the wheel well. Just need to get it to the alignment shop. Below is a before and after for easy reference. thanks everyone for your help and suggestions. Next step is to polish and paint the grille and install new FRT bumper.
Old 01-11-2010, 02:21 PM   #14
Sinister
Between Trucks...
Sinister's Avatar
Nice stance, truck looks great.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 01-11-2010, 03:07 PM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Perfect! Lookin' good...
-Nate
Old 01-11-2010, 03:11 PM   #16
JWall
Frequent Flyer
JWall's Avatar
Looks good!
- Justin
1 Owner 1976 SWB
Old 01-11-2010, 05:03 PM   #17
Mike J
vw guy & now c-10 guy
Mike J's Avatar
don't you if we're allowed to ask in a regular thread or not but, are you gonna sell the painted bumpers? I'm looking for some.
if I shouldn't have asked, sorry!
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 01-11-2010, 05:07 PM   #18
NicoSlam
Yes i was planning on getting rid of them along with the bolts. PM me if your interested. I was waiting to remove the front before I attempt to advertise.
Old 01-11-2010, 07:27 PM   #19
powell72
powell72's Avatar
Hey guys, don't do this, since neither of you are site supporters this will get this thread locked. I'd hate to see this happen in you progress thread Nico.
Truck looks really good BTW.
Chris
Old 01-11-2010, 11:31 PM   #20
NicoSlam
Sorry about that.
Old 01-12-2010, 09:08 PM   #21
powell72
powell72's Avatar
Sorry about that.
I just figured I'd let ya know, I didn't want to see your thread locked.
Chris
