Electrical weirdness
I replaced my turn signal switch, floor dimmer switch, and the brake light switch. Everything works great but when I turn on my headlights, the right turn indicator in the cab comes on and stays on and the right turn signal doesn't flash outside the truck in front of back, and the rear tail light goes dark except for the side marker light. This is on the 1974 4x2 btw....any ideas?
Re: Electrical weirdness
Check all grounds. the headlight grounds are on the core support.
Robert Olson Transport
![]() Join Date: Oct 2002
check the turn signal wiring harness make sure its in right and also make sure nothing could be arcing
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Already did that, and it is all plugged in right at the connector. I tend to think it may be a ground deal at the headlights so I will check that tonight...any other ideas while I am online?
only other thing that comes to mind are you sure you have the right bulbs in the sockets? i had a problem when i had an 1156 in an 1157 socket
#6 | |
thanks for the reminder! Kevin |
#7 | |
The One And Only !!!
What's this !!! We have a psychic on the board ? ![]()
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Addicted to Rust
![]() Join Date: Dec 2009
No just the voice of painful experience.
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
i actually had pretty much the same problem execpt both my indicaters lit up. and also my gas gauge would drop wayyyyyy below E when ever i would turn my lights on. i had a spare cluster layin around swapped it in. problem solved.
