01-05-2010, 11:31 AM | #1 |
71-72 Door help
Is there a diffrence in a 71 and a 72 door?
Brandon |
01-05-2010, 11:34 AM | #2 |
Re: 71-72 Door help
Yes, the 72 has a dimple below the wing window for a screw. Sorry I don't have a pic for you.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
01-05-2010, 11:35 AM | #3 |
Re: 71-72 Door help
I believe '72 is a one-year only - but I think all you have to do is change out the door mechanism to make it work for earlier door panels. They do have the screw in the upper front corner.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
01-05-2010, 12:47 PM | #4 |
Re: 71-72 Door help
ok thanks guys
Brandon |
01-05-2010, 01:07 PM | #5 |
Re: 71-72 Door help
x2 on what dan said. with out changing the mech. the 72 panel is the only panel that will work.
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
01-05-2010, 01:52 PM | #6 |
Moderator
Re: 71-72 Door help
The 72 doors are nice. The reinforcement screw keeps the vent window frame sandwiched nice and tight in the door frame. The only mechanical difference is the window regulator, which if switched out, will allow you to use the earler style door panels as stated above.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
