01-05-2010, 02:39 PM | #1 |
factory oil pressure gauge 60lb ??
Was the standard oil pressure gauge for a 350 engine 60lbs on a 72 Blazer ??
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
01-05-2010, 03:28 PM | #2 |
Re: factory oil pressure gauge 60lb ??
Yes. Small blocks are 60 and big blocks are 80.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
01-05-2010, 03:42 PM | #3 |
I wasn't aware of numbers on the 70-72 gauges, and didn't know bigblocks were part of the blazer line.
I can tell you my 72 blazer oil pressure gauge does coincide with a hand held mechanical gauge I had T'd into just for a comparison. And when the factory gauge was pegged it matched very close to the 60 lbs. mark on my handheld. My 79 pickup with a factory 454 doesn't have an 80lbs. gauge either. Neither did the 77 bigblock I had before that. They were also all 60 lbs. gauges,,,with actual numbers on the gauge in those years. |
01-05-2010, 04:07 PM | #4 | |
you are right, no BB in Blazers but lots of gauge panels swapped in and out so you may have an 80 where a 60 would have been stock.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-05-2010, 04:10 PM | #5 | |
With that said then the original posters best bet is to do what I did, and temporarily hook another mechanical gauge up just to see how it reads in comparison. |
01-05-2010, 09:56 PM | #6 |
Sorry for the confusion. My post was a general, "across the board" statement in regards to the entire 67-72 body style. If you pull the gauge out of the panel you will see where it says 60 or 80lb. I believe they used a 60lb in all applications from 73 up.
01-06-2010, 01:42 PM | #7 | |
Oooops, my bad. I gotcha now. |
01-06-2010, 07:54 PM | #8 |
Thanks for the responses. I see now where when removed it is printed on the lower face. 80lb might be the way to go with fresh higher performance 383 always seems to peg the guage full over.
01-06-2010, 08:43 PM | #9 |
Roadtrip!
I think the 80 pound gauges were found in the C-40 and bigger trucks. I believe everything from C-10-C-30 was a 60 pound regardless of engine size.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-06-2010, 09:34 PM | #10 |
I hope my oil gauge never goes bad, don't know if I can lift a 60lb. gauge up into my dash, let alone an 80 lb. one
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-06-2010 at 09:35 PM. |
01-06-2010, 09:38 PM | #11 |
Future TOTM Winner
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
09-14-2018, 03:41 AM | #12 |
