Old 01-05-2010, 06:09 PM   #1
cochino12
It followed me home?
cochino12's Avatar
tire help for rally wheels
I've been searching for a couple hours and cant seem to find exactly what I am looking for so here we go again.
My blazer lowered about 5-6" (3" spindle, spring, big block) front with van rally's (8" truck rally's rub a ton dont want to grind any more) and flip kit rear 8" truck rally. I need to pick some tires to run on my rally's until I find some larger diameter wheels I like.
I want as wide a tire as I can get in the back to help with traction and I also like the look, the front I dont want any rubbing issues at all. Currently I have 235-60 fronts and 295-50 rears but the front are just too short , looks like I need to replace all four because anything taller in front will be taller than the 295's in the rear. Suggestions? pictures of your setup would be great, thanks
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-05-2010, 06:48 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: tire help for rally wheels
so are you saying your still running van rallies then 215/70-15 front and 275/60-15 rear
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-05-2010, 07:54 PM   #3
cochino12
cochino12's Avatar
I'd rather run truck rally's because the van wheels just look really sucked in. I dont think I can grind enough off of the lca to clear the wider truck wheels.
I was thinking maybe a 235-70 front and 275-60 rears, I dont want the front to look to narrow escpecially after they are tucked in another inch from the van wheels
EDIT: typed wrong tire size
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-05-2010, 08:06 PM   #4
SCOTI
SCOTI's Avatar
I was thinking maybe a 235-70 front and 275-70 rears, I dont want the front to look to narrow escpecially after they are tucked in another inch from the van wheels
The 235-70 @ 27.9" might rub up front. A 205-75 would fit the van ralley better & is 27" tall. The next best thing on a truck rally would be the 225-70 @ 27.5" tall. I've never seen a 275-70 but have seen 285-70 BFG's (now called Silvertowns). A 275-60 is 28" tall or the 285-70's would be a little over 30".
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-05-2010, 08:31 PM   #5
texassquarebodies
Truck Nut
texassquarebodies's Avatar
On my dropped 87' burb I run a 7" truck rally with a bfg 225/70 and on the rear a 8" rally with a bfg 275/60. Front tire is less than an 1/2" shorter than the rear.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 01-05-2010, 08:32 PM   #6
68Timber
I know the pieces fit
68Timber's Avatar
Here's a pic of mine on those size tires when I was trying options. Mine isn't as low as yours (obviously) and I don't know the size of the spare rim. I had it powdercoated when I had my 15x10 rally's done but I never measured it.
EDIT: I never said what drop the truck has. Summit (Ground Force) 3" front springs, new factory rear springs from Husky with a 2" shackle drop.
The rake is not nearly as extreme as the picture shows, the truck was parked on a low spot or something. It does have a bit of rake, but where the truck was parked for those pictures makes the rake look a whole heap more than it is.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Last edited by 68Timber; 01-05-2010 at 08:59 PM. Reason: making excuses for a bad look
Old 01-05-2010, 08:49 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Here's my old '82.
15x7 and 15x8 ralleys.
215/70-15's and 275/60-15's.
Approximately a 4"/5" drop.
Old 01-05-2010, 11:57 PM   #8
cochino12
cochino12's Avatar
Thanks for the pics guys, I think I'm going to have to raise the front of the truck another inch or so. It sits way too low right now for a 26" tire, I think I'll order the tires and see how it sits with them mounted up before I try changing anything. The O.D. of the 15" will be really close to what a 20" will be so I shouldnt have to change anything later.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-06-2010, 11:49 AM   #9
blazer2007
I have 285/70 and 235/70 15,s n my blazer,I have bags in the fr and a flip in the rear with a 1in block
blazer2007 is offline   Reply With Quote
Old 01-06-2010, 02:55 PM   #10
texasfunk
texasfunk's Avatar
wow! whered u find 285/70's? i love those!
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 01-06-2010, 06:41 PM   #11
Chlsnk
Chlsnk's Avatar
I 2nd that your blazer looks killer good work !
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 01-07-2010, 12:12 PM   #12
blazer2007
I got them bf goodrich,I know some of you say you can,t find them but there still out there,alot of guys use them on their roadsters
Old 01-07-2010, 12:49 PM   #13
SCOTI
SCOTI's Avatar
As I stated earlier, Coker tire now sells them as Silvertowns....
http://store.coker.com/285-70r15-bf-...blackwall.html
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-07-2010, 01:46 PM   #14
Jonboy
Slots go on anything!
Coker is also showing a 285/60 Radial T/A that is 29.5" tall and will fit an 8-10" rim.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 01-07-2010, 02:47 PM   #15
SCOTI
SCOTI's Avatar
They make a 285-60-16. I didn't see a 285-60-15.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-07-2010, 03:08 PM   #16
Jonboy
You're entirely right. I was ready to keep my rallies for a little bit, too. Oh well.
Old 01-07-2010, 08:34 PM   #17
low86c10
front:205/70/15 with van rallies(5" drop)
Rear:235/75/15 with 7"s (6" drop)
low86c10 is offline   Reply With Quote
Old 01-07-2010, 09:24 PM   #18
jdurant
Why , oh why can't they make a 285/60/15?
I think the best most reasonable option for what you are looking for would be:
BFG Radial T/As 225/70 up front
in back a 285/70 Radial T/A,
Which, like Scoti said, is now manufactured by Coker under the name Silvertown--and they are pretty proud of them. Other than that it's either what you've got or 275/60
Joseph
87 Turbo Buick
92 5.0 Mustang coupe
87 GMC Sierra SWB
82 Chevy K5 Blazer 2wd
jdurant is offline   Reply With Quote
Old 01-07-2010, 09:35 PM   #19
low86c10
i know this one has 205/70/15 on the front with van rallies and 275/60/15 on the rear with 8"s
Old 01-07-2010, 09:51 PM   #20
BGRAFX
adam-check out these rallies I found online.
BGRAFX is offline   Reply With Quote
Old 01-07-2010, 09:59 PM   #21
lolife99
lolife99's Avatar
Those appear to be just stock steel wheels painted up.
Are they wider than 7 inches?
Old 01-07-2010, 10:09 PM   #22
BGRAFX
I don't know anything about those rims. I found them online awhile back and saved the pics.
www.ratrodstudios.com
Old 01-07-2010, 10:56 PM   #23
cochino12
cochino12's Avatar
I love that truck!! its bagged though right?
I think you are right, I think I'll order the 225-70's and 275-60's next week
Those are kind of cool, not my style but I do like them
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-07-2010, 11:18 PM   #24
low86c10
well its not mine but im pretty its not bagged
Old 01-07-2010, 11:22 PM   #25
3r!c84
Badass
3r!c84's Avatar
thats just a stencil i had one and did my lawnmower up like that
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
