Old 01-06-2010, 09:18 PM   #1
Mark B
Mark B's Avatar
Gas tank filler neck grommet installation
Can a new filler neck grommet be installed without taking out the gas tank? Can it stretch over the neck from the outside?
thanks
Mark
1970 c10
Mark B is offline   Reply With Quote
Old 01-06-2010, 10:56 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Gas tank filler neck grommet installation
Soap up the grommet good, slip over neck and used a pick from the inside of cab to help pull the lip over.
hayhauler71 is offline   Reply With Quote
Old 01-06-2010, 11:58 PM   #3
Duncan and son
The answer to your two questions... yes yes. Hayhauler is on the right track.
Paul
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 02-10-2015, 10:35 PM   #4
RBall
Here's the trick. Put the grommet in a pan of boiling water and heat it up. Hot enough so you can just barely hold it your hands. Lube it up with dish soap or WD40 and it will go right in. This also works for installing new vent window rubber (which is pretty hard). I've used this method for more than 30 years and it works every time.
RBall is offline   Reply With Quote
Old 02-10-2015, 11:07 PM   #5
AirSpeed
AirSpeed's Avatar
Ky jelly.
AirSpeed is offline   Reply With Quote
Old 02-10-2015, 11:21 PM   #6
leddzepp
Moderator
leddzepp's Avatar
I've always used WD40 and they pop right in.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-11-2015, 09:45 PM   #7
joeydurango
joeydurango's Avatar
Once you get it installed, you can use a little silicone caulk to actually make it weatherproof...
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 02-12-2015, 12:08 PM   #8
briscuba
briscuba's Avatar
Great info. wish I had known that BEFORE I had to muscle out the seat and gas tank..!
1967 C10: My next project
1964 SS Impala Hardtop, low and slow
2007 Harley Street Glide .... When all else fails to start.
briscuba is offline   Reply With Quote
Old 02-12-2015, 01:01 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
For replacement grommets you only need to know two words: Classic Heartbeat....
LockDoc
"Hey you guys having all the trouble with your gas filler grommets... We have had our own grommet produced and we provide a 5 year warrantee against cracking, fading or any degradation. Made in the USA!! They are not as cheap as the others but you wont be pulling your tank every few months replacing it either.... WES"
http://www.classicheartbeat.com/
No I don't work for them, or own the business...
Leon
Old 02-12-2015, 01:32 PM   #10
flashed
I completely agree with LocDoc above .I bought 2 of the grommets from another supplyer and not even a year out they were shot ,completely rotten .I have since replaced them with the ones from ClassicHeartbeat .
flashed is offline   Reply With Quote
Old 02-12-2015, 02:21 PM   #11
The Swed
The Swed's Avatar
They're out of stock...
1970 C20 350/TH350, LB
God Bless our Troops
The Swed is offline   Reply With Quote
Old 02-12-2015, 02:33 PM   #12
LockDoc
LockDoc's Avatar
I looked at that too. I think that is just for the New Old Stock ones. Call and talk to Wes about what you need. I think he is reproducing them now.
LockDoc
Leon
Old 02-12-2015, 03:36 PM   #13
The Swed
The Swed's Avatar
Old 02-12-2015, 03:46 PM   #14
1972BlueC20
1972BlueC20's Avatar
Not to hijack the thread, but how do you get the old grommet off without scratching the paint or damaging anything?
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 02-12-2015, 07:58 PM   #15
flashed
I took a new and very sharp razor knife and cut around the perimeter of the gas filler neck and then pushed it thru into the cab with a screw driver .Im sure there is probably a better or easier way but it worked for me twice .
When I installed the new ones I rubbed the filler neck and the grommet with baby oil and worked it right in place .
