Old 01-07-2010, 11:27 AM   #1
KrazyKevin
What have I gotten into
KrazyKevin's Avatar
700R4 Crossmember: Will this one work?
Got my frame painted and while the cab is off I'm wanting to install a new crossmember for the 700r4. My truck had a old 3 speed manual on the column. I found this one:
http://www.resto-modtechnology.com/s...%7C-GMC/Detail
If this will work, whats the easiest way to get this thing mounted properly? I can see myself mounting this thing and it being off 1/2" or so and really giving me he77!!! I have a 72', will there already be holes drilled?
I'm off to do more searching.
1972 Chevy SWB Fleetside
Project BumbleBee
KrazyKevin is offline   Reply With Quote
Old 01-07-2010, 01:26 PM   #2
Wrenchbender Ret
Re: 700R4 Crossmember: Will this one work?
That looks like a nice piece. I'd say you will have to have the engine & tran. setting in the frame to get it lined up & then drill the holes. I supose you have removed the crossmember that went under the bell housing.
Wrenchbender Ret is offline   Reply With Quote
Old 01-07-2010, 01:32 PM   #3
cdowns
cdowns's Avatar
putting engine and tranny in place would b best, you might b able to use existing mounting holes in the frame// yes the original bellhousing mount crossmember needs to go
i believe GMC paul's carries that type crossmember too,so check with him on pricing
Old 01-07-2010, 04:04 PM   #4
425HP409
425hp409
425HP409's Avatar
I installed a 700R4 in my 68 that was a Powerglide truck and just moved the existing cross member and drilled the appropriate holes. The one you showed looks good, or maybe you could find an original from someone on the forum.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 01-07-2010, 04:17 PM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
That's a nice looking piece - much beefier than the tubular ones you see that only bolt to the bottom of the frame. My '69 started with a powerglide, then a TH400, now a Tremec TKO - and I used the original crossmember. Lots of holes drilled! I would do a lot of measuring so you save yourself the trouble of having to re-drill holes, especially since you'll be drilling holes in the top and bottom of the frame.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-07-2010, 04:25 PM   #6
KrazyKevin
KrazyKevin's Avatar
Thanks so much for the replies. Since the engine is not rebuilt, nor the 700r4 purchased, sounds like I might need to wait. Just seemed like something I needed to do now before the cab went on. But, I guess I'd rather wait then to have holes all in the frame.
Project BumbleBee
Old 01-07-2010, 04:34 PM   #7
Thealien
Thealien's Avatar
If you want you can use this
Website
and use the transmission mount measurement differences to figure where the crossmember needs to go. Personally I would wait and mark the holes with everything in place.
Old 01-07-2010, 04:47 PM   #8
Clyde65
Clyde65's Avatar
I have one just like that, works well. I also have one that i ordered cuz I didnt pay attention to what I already had let me know if you would want to purchase it, I will be generous with the cost.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
