#601 |
Member of the longbed union.
Re: What did you do to your truck today?
I pulled the carb off my truck to sell. And I was going to pull the gears out of the rear end to trade.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#602 |
Redefining LowBudget
I shoveled out the garage door backed the truck out and then picked my way around town to avoid the wet/salty parts of the road went down picked up some flooring and took the trash out
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#603 |
Senior Enthusiast
Received new trailing arm bushings today. Got the garage cleaned up ready for another project. Think I'll probably wait a bit before tearing it apart though, not too crazy about working on it when the ambient is 24 and the garage is 42 degrees.
#604 |
I got my bags in the mail today
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#605 |
awesome- front and rear ? next truck I build will be bagged w/ custom frame , how much do you think a whole air system will set me back? Eric
If it has tits or wheels its gonna give you problems!!! |
#606 |
Sunburst C10!!!
i changed carbs but i gotta change em back
p.o.s. holleys ![]() back to the good old q-jets and that crappy adapter i have to use haha
Gage 1967 C10 Shortbed Stepside |
#607 |
You need to learn how to tune the Holleys
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
#608 |
finished my bucket seats building my sub box and comsole and got it all installed
sorry for bad pics the sub box goes across behind the seats ![]() ![]() Last edited by midnite; 01-09-2010 at 12:58 AM. |
#609 |
I've been trying to get things done on my project 64 but feel as if I'm getting no where fast..... So, today I decided my task would be to make lists of items needed to be done (hey, if it helps get it done, it counts right?
![]() I organized the tasks into groups & I'm going to try & use the list like 'assignments' to complete each week. I thought maybe sharing the list might help my motivation even more: Rolling Chassis I need to.... Get the gas tank 'fill' piping determined & routed DONE Finish my upper rear shock mounts DONE Determine rear bumper bracket placement Finalize bed floor mounting (switching to steel floor & raising @ the same time)DONE Finish machining my truck-arm spacersDONE Make rear bag hats to install the bagsDONE Get the tranny x-member mounted Determine exhaust routingDONE Paint/powder-coat the frame, x-members, cab mounts, & various brackets Route fuel lines Route brake lines Route air lines Mount air tanks & compressors Purchase rear wheels DONE Purchase rear tires DONE Purchase shocks DONE Drivetrain Repaint the motor (different 'theme' warrants a different color) Paint the tranny Mount the accessories (already got them powder-coated and/or detailed) Mount radiator Mount electric fan Wire fans & headlight relays Re-wire for internal alternator (hi-amp conversion) Mount brake assembly (vac booster/master cyl, & firewall adapter bracket) Mount trans cooler Interior Clean/scrub cab interior Install high-hump trans tunnel cover Install sound/heat insulation Remove 'cassette' style radio for delete plate R&R manual column for van auto tilt Remove clutch pedal Purchase carpet & install Mount seat (already re-covered) Route air-lines from controller to tanks/bags R&R front windshield R&R dash cluster from 'lights' to analog gauges And finally, my list for this week.... Set the steel floor in place to finalize my fuel fill routing planned for Sunday.... DONE Finish fitting my fabricated upper shock plates to the shock x-member DONE Trim the PB dropped truck arm Panhard bar bracket DONE I finished this before cutting the shock x-member c-sections
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-19-2010 at 09:29 AM. |
#610 |
Nada...with the temps below zero and a foot of snow on the ground, my "get up and go has got up and went". May the sun return soon and the snow melt away.
#611 |
#612 |
I just got the rear. I paid 100 for both. They are Air-Lift 2600's. I'm not too sure how much a whole set up will be. I have access to most of the stuff. Air tank, lines, fittings etc. plus I built everything. But I'll have to buy a compressor and some solonoids. In Street Trucks the company Airbaggit has some pretty sweet kits that seem like pretty good deals. If I was to estemate it I would guess around 1500??
#613 | |
#614 |
Or you could just build your own kit and pay a whole lot less and end up with something to be proud of. I've only bought the poly bushings, bags and a bag of bolts.
#615 |
I wasn't being specific about using a 'kit'. I just know guys have had issue w/that company (AIM, aka Chassis Tech, airbagit.com, etc...).
#616 |
Hey SCOTI I think we have Stella's almost identical twin
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
#617 | |
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 Last edited by sams60gmc; 01-09-2010 at 04:10 PM. |
#618 |
hooked up my voltage regulator today, Also wired up a gas guage that is not work right and a voltage guage. Looks like I have some trouble shooting to do. I was going to bleed my brakes but, that is going to have to wait a week. After the brakes, the bed is going to come off and I am going to start cleaning and painting. Then I am gonna take a coil off the front and remove a few leafs in the back. I will try and get some pictures up soon.
#619 |
![]() Join Date: Dec 2008
Cut a quarter of my bed off with a hacksaw,sounds stupid but I rent the garage and it has no electricity. Note that my bed is 3/8 diamond plate so clean cuts really don't matter to me, I'm just scrapping the bed anyway. Pulled the wiring, cut the rusty exhaust off, moved the extra block and heads to the engine stand, drained some of the coolant, took the hood hinges off to be cleaned and painted, knocked some rust and dried mud out of the frame and off of the rear suspension and cleaned up the rest of my crap laying around.
I forgot to take pictures of it but my frame looks like it was cut off with an air chisel. |
#620 |
Wired up my amp sounds great then took it for a spin. Man it felt good I havent drivin it for about a month, I was starting to get the shakes
#621 |
Zero Albedo
Commuted the last 2 days to work in the 64 without a hitch or a worry.
50 mi each way- this thing starts, handles, runs better than the 66 which is getting tired out.
Baz "Deserve's got nothin' to do with it." 66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467 65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432 65 Chevy Panel (former U.S.Navy truck) 64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348 64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now) 68 Dodge Charger |
#622 |
Shlong Bed Club
Finished painting my freshly built 400hp/450tq 350. Planning on towing my truck to work Monday to install the '79 crossmember and then the engine and camaro t5. busy busy busy...
#623 |
Getting tired of trying to get bed adjusted..........Cannot git rid of this problem, how much is to much for shims. To get tailgate to close on this top side I have to shim the other back side of bed up 3/8 inch and then bed doesn't set level..........Help any suggestions.......
#624 |
![]() Join Date: May 2009
[quote=198plus;3721244]Getting tired of trying to get bed adjusted..........Cannot git rid of this problem, how much is to much for shims. To get tailgate to close on this top side I have to shim the other back side of bed up 3/8 inch and then bed doesn't set level..........Help any suggestions.......
It looks like the tail gate may be tweaked, I guess you could tweak it back but not sure of how to do it. Maybe someone knows the procedure out there.Body guys?? Vernski ![]() |
#625 | |
I've tried tweaking it back........I really don't think it is the tail gate ?????
[quote=Vernski;3721354] Quote:
