Old 01-07-2010, 06:06 PM   #1
adpostel
New Member
How's Your Steering Ratio?
I have noticed that my truck turns alot tighter to the left than to the right. The other day I was going around the block, and I almost couldn't even turn right out onto the street without hitting the curb across the street. I almost had to back up and straighten her out. I know the PO replaced most of the front end from an 84-86ish truck. Is this normal, or is something not right here? Shouldn't it turn equal amounts both ways?
1968 C10 LWB Project 454/400
http://www.cardomain.com/ride/2417713
adpostel is offline   Reply With Quote
Old 01-07-2010, 06:35 PM   #2
CCCC
CCCC's Avatar
Re: How's Your Steering Ratio?
Originally Posted by adpostel View Post
. . .my truck turns alot tighter to the left than to the right. The other day I was going around the block, and I almost couldn't even turn right out onto the street . . .
Your instincts are good - I'll bet on on "abnormal".
First, look for interference on one side of steering link/arm or near wheel - let's hope it is obvious. If not that, you could have a failure on a part of the worm gear/drive in the box.
Is this truck new to you? While not very likely, someone may have re-installed the steering box with the gear action not centered. I have never seen that and am not certain what would happen, but might give the effect you are experiencing.
Best wishes,
CCCC
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 01-07-2010, 06:46 PM   #3
skidder111
skidder111's Avatar
If it is a 4x4 and has an aftermarket steering stabilizer (the bolt-on type) it may not be centered properly on the tie rod.
skidder111 is offline   Reply With Quote
Old 01-07-2010, 06:49 PM   #4
Sammy
I had a stock 71 power gear box fail. I had never heard any of them fail and act this way. Mine a failed all at once making a slow speed L/H turn. It locked up completely, then would only go straight ahead or to the right. Suspected worm gear failure. So they do wear out internally even with out leakage or warning ahead of time.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 01-07-2010, 07:34 PM   #5
Jebb1978
Jebb1978's Avatar
It may be the front end parts they used. My Dad drives an 84 K10 and it has the same issue only on that side. Weird, my truck turns tight on both sides and it's much older.....
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 01-07-2010, 10:29 PM   #6
truckster
truckster's Avatar
I had a used NASCAR that would only turn left. Weird.
truckster is offline   Reply With Quote
Old 01-08-2010, 11:47 AM   #7
Wrenchbender Ret
More then likely the tie rod sleeves are out of adjustment. Point the wheels straight ahead & look under the front of the truck. The pitman arm & idler arm should point straight back. The inner tie rods ends should be in the same relative position to the frame channels. If they are off you need to adjust the sleevs to get them even & set the toe-in.
Wrenchbender Ret is offline   Reply With Quote
Old 01-08-2010, 02:07 PM   #8
adpostel
New Member
No, the truck isn't new to me, although it has been undergoing a build for the past couple of years. I used to drive it everyday, and I did remember it being odd then, but I never thought to actually look under the hood to see if anything was abnormal. I guess I'll be checking it all out now. I just got my insurance and registration, working on getting it to the inspection shop. I'm ready to drive this thing and have some fun.....
