Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-07-2010, 05:56 PM   #1
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Wiper issue
My wifes 200 Blazer has developed a wiper issue.The drivers side just seems to have quit working.It tries to mo0ve but doen't.I think it may be the wiper arm/shft is stripped but I don't have any idea how to remove the wiper arm to check.I'm assuming it may just pry straight up like the earlier models but don't want to damage anything if it doesn't.
BTW It is the original arm but has had new blades quite often.
Any ideas and TIA for any info.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-07-2010, 07:16 PM   #2
clinebarger
Re: Wiper issue
My book says that it bolts on, maybe the nut backed off.
clinebarger is offline   Reply With Quote
Old 01-07-2010, 07:31 PM   #3
PanelDeland
Re: Wiper issue
Thanks clinebarger,I thought there might be a trick and sure enough there was.I appreciate the quick response.
Old 01-07-2010, 11:16 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
Re: Wiper issue
after you remove the arm take an O-ring pick and scrape the tapered splines clean.
did your wipers freeze to the windshield? I always free them when scraping my windows so this doesn't happen.
BTW, to remove the arm I take off the cover, loosen the nut, swing the arm up and wiggle it loose. then remove the nut followed by the arm.
68C15 is offline   Reply With Quote
