Old 01-08-2010, 10:40 AM   #26
Burt4x4
Burt4x4's Avatar
Re: Transmission case broke....again.
YYYYYYYYYYYEEEEEEEEEEHHHHHHAAAAAAAAAAAAAAA!!
That otta hold er together
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-08-2010, 02:54 PM   #27
OrrieG
OrrieG's Avatar
Some one is going to have fun with the cooler lines and fill tube. Looks like a custom hump will be in order too.
Old 01-08-2010, 07:50 PM   #28
Chroming or two-tone powdercoating it?It needs some spider webs welded as gussets.I`d hate to see that bend,you know.
Old 01-08-2010, 08:23 PM   #29
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Tranny lines clear as is and the stock hump clears, but I will need to switch to a flexible trans dipstick. It looks like the linkage for the column shifter will still clear as well and the t-case shifter clears and can still be removed.
Also will need new exhaust to clear but I needed that anyway.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 01-08-2010, 08:26 PM   #30
johnnywagon
Funny thing is Im working on this at a friends shop and he is the truck's PO! He still has more of the yellow he painted the body with so red tranny, yellow truss.
......I seriously did consider powder coat.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-08-2010, 08:34 PM   #31
johnnywagon
Not painted yet but all fabbing is done. Tunnel shots show how much clearance there should be.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-09-2010, 09:52 AM   #32
That`ll be purdy> Powder coat would have a practicle use there.Maybe not 2-tone.
Old 01-13-2010, 10:51 PM   #33
johnnywagon
Safety Red:
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-13-2010, 10:57 PM   #34
johnnywagon
While the transmission & t-case are out Im finally going to deal with the bent/twisted frame. Im adding a cross member in front of the front leaf spring shackles. I used a scissor jack & 2x4 to spread the rails 1.5" apart...close to where they should be. The bolt-in cross member isnt done yet but you can see the progress.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-14-2010, 12:18 AM   #35
onlyifihadachevy
hey I was looking at your wheeling pics, and when you ran boggers, looked like your truck, which way did you like the front tires better? The right way or backwards?
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 01-14-2010, 01:31 PM   #36
johnnywagon
A friend of mine lent me a set of 38" Boggers last time I went to the Moyie Mud Bog. Tried them backwards one day and normal the next day. Didnt notice any difference.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-14-2010, 03:16 PM   #37
Burt4x4
Burt4x4's Avatar
Lookin Good John!
Old 01-15-2010, 09:21 PM   #38
johnnywagon
Thanks Burt!
The cross member is finished and installed. The transmission and t-case are getting closer.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-15-2010, 09:37 PM   #39
y5mgisi
Second Chance Program
y5mgisi's Avatar
I fully expect you to beat this thing to death and then some to put that design to the test! I like the idea alot, and if it works, i just might steal it!
y5mgisi is offline   Reply With Quote
Old 01-21-2010, 12:23 AM   #40
johnnywagon
Getting closer. Trans/T-case/Cradle are installed and everything clears. Even got the stock dipstick to work...after bending the hell out of it. I bought a set of Jeep/Chevy swap headers because they looked like they would fit and they do with minor trimming. I needed the shorty style headers to clear the new crossmember and the transmission cradle. I also added a small bracket/brace that connects the trans mount to the rear two bolts of the trans pan. This straddles the area where I broke the other two transmissions.
Now just some minor buttoning up, re-install drivelines and fab up temporary exhaust to get her to the muffler shop.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-21-2010, 02:02 AM   #41
y5mgisi
y5mgisi's Avatar
Old 01-21-2010, 01:44 PM   #42
Blue_71
Bloo
Blue_71's Avatar
um... WOW.... thats all i know to say... LOL i wonder if part of the problem wasnt the NP205? those suckers are heavy as heck compared to all the aluminum t-cases
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 01-22-2010, 10:48 AM   #43
Burt4x4
Burt4x4's Avatar
Hell ya
Old 01-22-2010, 09:36 PM   #44
y5mgisi
y5mgisi's Avatar
Get out and abuse the thing already!
Old 01-23-2010, 10:05 PM   #45
johnnywagon
Test run tomorrow!
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-23-2010, 11:45 PM   #46
y5mgisi
y5mgisi's Avatar
Hooray!
Old 01-25-2010, 02:10 AM   #47
johnnywagon
Well, the new transmission seems fine but my "new" (used) transfer case isnt. It wont stay in 4-low. It will in reverse, but just pops out in drive. Then after "driving angry" in 4-high, I broke the front yoke on front drive shaft.
I guess its a "good" thing because I found a nasty crack in the transfer case front output shaft yoke while pulling the drive shaft.
Looks like I'll be putting my old t-case back in. That will be THREE R & R's of the t-case in 2 months.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-25-2010, 02:46 AM   #48
y5mgisi
y5mgisi's Avatar
Well that sucks. Good to hear the trans works good and held up so far!
Old 06-27-2010, 04:32 PM   #49
tomtuna1978
you got any updates ? u get the t-case back in ?
tomtuna1978 is offline   Reply With Quote
Old 06-27-2010, 09:49 PM   #50
johnnywagon
Oh yeah! Been out many times and everything is working great!
~John
71 Blazer One Ton
59 Belair 2 Door
