Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-04-2010, 01:41 PM   #1
Tom
driving is in my blood
Tom's Avatar
Simple question
I have a component set of 6.5"s and 1" tweeters up front in my truck. Does the component set require 2 channels [one channel to drive each pair] from an amp or 4 [one for each speaker]?
Old 01-04-2010, 05:28 PM   #2
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
Re: Simple question
From what I've heard its 1 channel per pair.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 01-04-2010, 07:29 PM   #3
AceX
>130dB Moderator
AceX's Avatar
Re: Simple question
1 channel/pair passive. 2 channel/pair active.
Passive = using the little x-over box that came with the speakers
Active = throwing that little box in the trash and using a signal processor to tell the speakers what to do.
I'm going with you're on passive, so it's one channel per mid/tweeter, so a 2ch amp is what you're looking for.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 01-04-2010, 11:20 PM   #4
Tom
Tom's Avatar
Re: Simple question
AceX your correct,Im using the crossover box that came with the speakers. So if the setup is rated 200max/100 rms then I need one channel at 100 per side right? sounds simple enough. Thanks for the info guys.
Old 01-09-2010, 02:41 AM   #5
TheSunDanceKid
TheSunDanceKid's Avatar
Re: Simple question
you want a 2 channel for a set of compnets if you have rear speakers also 4 total and your tweeters you want to use a 4channel but you can also run the componets on a 4 channel and use the other 2 channels for a sub if you wanted some bass
you want a 2 channel that is not strickly a bass amp which most arnt just for bass there will be a cross over switch on the amp that has settings for hp (high pass) LP ( low pass)
and FULL you want the amp set to full
low pass=bass only
high pass=treble only
full=treble mid and bass
TheSunDanceKid is offline   Reply With Quote
