Old 01-09-2010, 07:10 PM   #26
ClassicDreamer
Re: how much horsepower does your truck have
here is another 553hp
http://www.chevyhiperformance.com/te...ild/index.html
ClassicDreamer is offline   Reply With Quote
Old 01-09-2010, 08:06 PM   #27
nebdrummer
nebdrummer's Avatar
hey, boost is addicting. no doubt about that!
i would love to do a twin 62-1 setup, but given all the extra weight that would be on the front of the already heavy 2150 lbs of my pickup, i wouldnt hook up period..
im going to be doing a midmount turbo setup with as much stuff moved behind the rear axle that i can get back there. should be fun!
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 01-09-2010, 11:27 PM   #28
mr48chev
mr48chev's Avatar
Horse power, I don't think you can count the engine in either of my trucks as having any horsepower. But enough to cruise at serious highway speeds for hours on end without issues is plenty.
Old 01-10-2010, 12:04 AM   #29
ClassicDreamer
neb, your going to run a system like STS turbosystems? Very cool. Always interested on how those work. What are you doing for cooling? FMIC? Air to Water?
Old 01-10-2010, 12:17 AM   #30
nebdrummer
nebdrummer's Avatar
well, the same basic principal as an sts.. try and hide as much as i can...
im going to TRY and mount the turbo where the battery box is now. *original location* and have full exhaust.. as far as intercooler goes, i dont need one unless im really pushing it. carborated systems play their own "cooling" role in the atomization of the fuel. so from what ive seen, i should be good without a cooler for up to 12-14 lbs. if i want to go higher, then ill just install a meth setup to help out there. but i shouldnt have to. 500 wheel should definetally be doable with 93 pump and that snail.
ignition, im going with a plane jane HEI with the simple upgrades and curve ket and MSD's new 6AL2. pretty cool, and very simple!
Old 01-10-2010, 02:48 AM   #31
CAL 58 GMC
CAL 58 GMC's Avatar
Originally Posted by pgf545 View Post
I am hoping about 8000 but I am really concerned that it is going to spin the tires....
Your going to have a hard time spinng those tires on a boat Bernie
CAL 58 GMC is offline   Reply With Quote
Old 01-10-2010, 04:05 AM   #32
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
I have a '68 307 that's rated at 200 hp and with a couple of bolt ons I'm hoping to get 300 hp; naturally aspirated of course.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 01-11-2010, 02:23 PM   #33
C10Slim
Will be running a 383 with 420 HP/450 TQ.
C10Slim is offline   Reply With Quote
Old 01-11-2010, 05:02 PM   #34
ClassicDreamer
c10slim. What truck are you putting in into? Suspension. Frame? Wheels?
Old 01-11-2010, 05:38 PM   #35
C10Slim
Sorry mine is going in a 66. I forgot I was browsing the 47-59 thread.
Old 01-11-2010, 06:42 PM   #36
ClassicDreamer
no worries, should have figured that based on your screenname (c10), anyway... what is your setup going to be?
Old 01-11-2010, 07:52 PM   #37
pro1955
pro1955's Avatar
290hp Goodwrench motor, runs 70 on freeway all day long. On good old regular pump gas, daily driver type rig. 68 Camaro 10 bolt, 273 gears, 70 A body subframe, turbo 350, it just doesn't get any more dependable.
Truck's just for the fun of it.
pro1955 is offline   Reply With Quote
Old 01-12-2010, 02:43 PM   #38
ClassicDreamer
Should have added this question too.
What suspension?
What rear end?
What chassis?
How does it hold up?
Old 01-12-2010, 02:44 PM   #39
ClassicDreamer
I am running a s10 chassis, leaf in rear, 2" drop spindles in front, 4x4 blazer rear end.
Old 01-12-2010, 02:59 PM   #40
C10Slim
383 backed by a TH400, stock frame, CPP Grand Slam kit 5/7 drop, tubular trailing arms, power disc brakes. Has a 12 bolt but going to upgrade to a posi don't know what gear yet. Rolling on 16x8 reverse smoothies with wide whites.
We'll see how well it holds up.
Old 01-12-2010, 08:32 PM   #41
TwoFiftyShifter
Our 1957 has the original 235 and has probably never even been rebuilt. Runs OK still.... I would guess it 100HP on a good day.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 01-14-2010, 10:15 AM   #42
samdjr74
I was planning on buying a GM crate motor but I got a really good deal on a freshly rebuilt 350. It was dyno'd at 400 HP and 450 FP tourque at the flywheel with a standard 4 barrel and edlebrock carb, I've probably reduced that with my 3x2 high rise but it should still get out of it's own way
samdjr74 is offline   Reply With Quote
Old 01-14-2010, 01:38 PM   #43
ClassicDreamer
Sam, how does it ride?
Old 01-15-2010, 09:26 AM   #44
samdjr74
No clue, the truck is road worthy yet, will be in a few months but I still have a lot of work to do before she hits the pavement.
Old 01-15-2010, 10:50 AM   #45
cajundragger
with my stock ls1, 4.10's, posi, and 6 speed I can break it loose it 1-3 and chirp hard going into 4 and 5.
I pleed the 5th for the speeds at which I shift haha
cajundragger is offline   Reply With Quote
Old 01-15-2010, 03:27 PM   #46
ClassicDreamer
Cajun, I was battling with the idea of going LS1 and putting a couple bolt ons, but got too good of a deal on a fully built 327. Was that with your 20x8s? How do you suppose it would grab with a 15 or 16x10 with street slick?
Old 04-07-2013, 04:57 AM   #47
jdougla9
Originally Posted by nebdrummer View Post
600 hp from a 327.. either lots and lots of money and spinning it to the moon, or lots and lots of money with boost.
right now im about 350-370 wheel and about 440 crank. upwards of 440-450 wheel tq though.
first gear stands no chance with radials.
and no you dont need fat meats to hook up.. and a 4 link properly setup will hook just fine with a 275/60/15 drag radial.. which is proven that runs in the 7's now. no im not saying these old heavy trucks can run that fast with the small tire, but they work.. and will work for what im going after
will be putting in a mild built 350 with forged pistons and for now, a holset turbo off a cummins bus in the truck. should support 500 wheel, then ill be upgrading to masterpowers 76 series turbo hoping for 600 wheel on 93 pump!
classic dreamer, im also wondering what makes ya think that a twin turbo setup isnt practical? minus the price? extremely efficient, able to run better mpg out of boost than a NA motor set up correctly. and you dont need a big cam to make power.
Will a 275 drag radial fit without cutting anything up? I have a little small block in myne and am getting ready to order wheels/tires. I was planning on a 15x10 with 4.5in backspacing and a M/T 275/60/15 drag radial. It looks like I might have to cut some of the bed out to make it fit, but it destroys the stock 225/60's on it now...
BTW 500+hp (est) 388 stroker here...
jdougla9 is offline   Reply With Quote
Old 04-07-2013, 05:02 AM   #48
jdougla9
https://sphotos-a.xx.fbcdn.net/hphot...75347663_n.jpg
Old 04-07-2013, 09:31 AM   #49
Speedbumpauto
Speedbumpauto's Avatar
It's installed in the wrong end!! I put mine in the correct end and figure a minumum of 100 HP......that's to the rear wheels!
Speedbumpauto is offline   Reply With Quote
Old 04-07-2013, 10:18 AM   #50
hotrod1
56 - autocross
hotrod1's Avatar
Originally Posted by Kabwe View Post
Here's a guy that goes to the local cruise in and he has power to spare. He starts this thing up and you can feel the engine all up in your chest.
Hey BAM: I would like to know more about his tilt front end.
hotrod1 is offline   Reply With Quote
