Old 01-11-2010, 12:37 AM   #1
TurnNBurn
Blower motor won't stop running Help
Hello I have had many old chevys like this. Where in the summer you open the hood and unplug the blower, but I want to fix this one. The truck i'm doing is a 78 1/2t 2wd. The fan control will not shut the blower motor off. I first off bought a new blower resistor in the heater box. That did not work, I have speed control now but it wont shut off. What do I try next?? The fan switch maybe??? btw no factory A/C
TurnNBurn is offline   Reply With Quote
Old 01-11-2010, 12:58 AM   #2
GMC Guy
GMC Guy's Avatar
Re: Blower motor won't stop running Help
i think they'll all like that. maybe you could hook up an in-line switch to the blower. i dunno what much else you can do.
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 01-11-2010, 01:11 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
The fan is designed to run all the time. You'll have to install a bypass switch to turn it off.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-11-2010, 01:15 AM   #4
TurnNBurn
seriously wow ok
Old 01-11-2010, 01:16 AM   #5
TurnNBurn
does any one know why
Old 01-11-2010, 01:18 AM   #6
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
I bought my 78 new in Dec. of 77. The salesman made a big deal of the blower being on constantly, calling it "Astro-Ventilation" or something of that sort. After 32 years, I'm used to it.
78 Big10 454 is offline   Reply With Quote
Old 01-11-2010, 01:25 AM   #7
TurnNBurn
OK Thats really odd, Do you know where I can find anymore info on this.
Old 01-11-2010, 02:39 AM   #8
spinem
haha, ford guys...
it runs all the time, chevys idea was to keep the heater core cool due to direct water pump-intake manifold hook up (not radiator hook up).... you can put an inline switch on it but make sure u use a beefy switch or a relay.
spinem is offline   Reply With Quote
Old 01-11-2010, 08:57 AM   #9
ToughBowtieTruck
Yep....I got rid of this little "option" a long time ago.
Here is how to do it:
You need to pull your dash bezel cover off, and unplug the harness from the fan switch. On the plug you will see I think a brown wire that jumps to 2 terminals at once. One of the terminals is the power to the switch and one is for the low speed, hence making the fan run all the time on low. You can cut that wire out - but be warned you will then only have medium and high speeds left. I don't care about low anyhow, truck is still cold in the winter on high ha ha.
-Josh
"Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division
"Yeah, they're called Congress!!" -Homer Simpson
ToughBowtieTruck is offline   Reply With Quote
Old 01-11-2010, 04:07 PM   #10
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
my question is why would you even wanna stop it from running? its been doing it for years and hasent hurt anything, i dunno just my 0.02 i guess
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 01-11-2010, 04:20 PM   #11
Keith Seymore
Keith Seymore's Avatar
Do you mean it runs full blast, like even after you shut the truck off and remove the key?
Or are you saying it runs at a low speed (only when the key is in the "on" position) even when you think the system should be "off"?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-12-2010, 08:53 AM   #12
ToughBowtieTruck
Way too hot in the summer for me.
-Josh
Old 01-12-2010, 09:27 AM   #13
joe231
joe231's Avatar
I just clipped the yellow wire at the blower resistor to get rid of low. I didn't need low anyway. And to kill the heat in the summer, I put a manual shut off valve in the heater hose. Made it much better.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-13-2010, 02:16 AM   #14
TurnNBurn
The Blower shuts off when I turn key off. I just thought that it should shut off when I tell it to. Also Its not really needed when its 100 above with 85% humidity. Its hot enought just running around town. I just find it odd that is doesnt shut off. I thought every pickup I have had has this problems.
Old 01-13-2010, 08:17 AM   #15
Keith Seymore
Ok, thanks.
I had a different problem: the blower was stuck on High no matter where I put the switch, and then remained running even when I shut the engine off and removed the key. I had to pull the power wire to the blower motor to keep the battery from running down.
After doing this for a couple days it finally "healed" itself. There is a module mounted on the case that is suspect; I will replace that module first thing if it ever does it again.
Thanks for the followup -
K
1979-1986
1986 - 2019
Old 01-13-2010, 08:27 AM   #16
68_Step
I had no idea they ran all the time - learn something new everyday in these forums.
Does it also run on low on a 67 C10? Or just square bodys?
68_Step is offline   Reply With Quote
Old 01-13-2010, 07:43 PM   #17
78-5.3
78-5.3's Avatar
on the note on the blower not turning off my blower doesnt work i pulled my blower and it dont spin freely also the fuse got really hot and blew could the fact its hard to spin make it not work and blow a fuse!!
78-5.3 is offline   Reply With Quote
Old 01-13-2010, 08:05 PM   #18
flamingbig10
6.0 powered square
flamingbig10's Avatar
yes
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
