Old 01-13-2010, 12:32 PM   #1
Sniper X
I must be dumb, but here's a question
Do I have to remove the rear axles to do brakes on the 74 C20? I was told by some dude that I did to service the back brakes. I need to put in new brake cylenders and adjusters. Thanks!
kev
Sniper X is offline   Reply With Quote
Old 01-13-2010, 12:57 PM   #2
manimal
manimal's Avatar
Re: I must be dumb, but here's a question
Yes. Once you remove the 8 bolts on the flange,smack it with a hammer and the axle will pop out. Then you'll see the large retainers and nuts that have to come off to get to the brakes. Good Luck.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 01-13-2010, 01:16 PM   #3
Sniper X
Is it a ***** to get the axles back in?
Old 01-13-2010, 01:45 PM   #4
Adams74Chevy
Adams74Chevy's Avatar
Not really just slide them in the wiggle a bit and the splines will slip into place.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 01-13-2010, 01:46 PM   #5
Sniper X
Sounds great. Thanks all, anything I should be worried about of know before tearing it apart?
Old 01-13-2010, 01:55 PM   #6
Adams74Chevy
Put a pan or small bucket under the end of the axle it will most likely drip a bit of gear oil out. It's pretty straight forward just bulkier/heavier than most drum brakes.
Old 01-13-2010, 04:14 PM   #7
82dropped
does anyone know what i can do to my 305 to get more power out of it?
82dropped is offline   Reply With Quote
Old 01-13-2010, 04:22 PM   #8
Adams74Chevy
Psst...Try here http://67-72chevytrucks.com/vboard/f...splay.php?f=24
not on a thread about rear drum brakes.
