Old 01-15-2010, 03:36 PM   #1
hotrodrookie
hotrodrookie's Avatar
Underbed fuel tank project
Well, its been too long since Ive made any progress on my truck but for the last 4 weeks I spent my winter vacation working at a sheetmetal manufacturing company that a friend of the family owns and Ive had this idea to make this for a long time. I drew out sketches and dimensions of all the pieces. We drew them up in the cad software then punched all the parts on the huge cnc turret punch. I had the break operator bend up the sides and step bend the roll and then I welded the baffles in with a Dynasty 350. My plans are to mount an intank fuel pump for my 5.3l but not quiet exactly sure which one yetHere is a teaser of the progress.
I still need to weld on the extruded angle to the sides so i can mount it to the truck and then figure out which fuel pump Im using so I can cut the hole on the top piece before I weld it on
And oh ya, it makes it soooo much easier when you have the right tools..
hotrodrookie is offline   Reply With Quote
Old 01-15-2010, 05:46 PM   #2
63 & 64 Bowties
and a few others
Re: Underbed fuel tank project
Nice work. I think you're gonna have to change your user name here. Rookie? I don't think so.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 01-15-2010, 06:06 PM   #3
hotrodrookie
Thanks, this is my first time building a tank and building a truck so eveything is learn as I go.
Old 01-15-2010, 08:50 PM   #4
OrrieG
OrrieG's Avatar
Nice, like you said, having the right tools makes a big difference.
Old 01-16-2010, 07:01 PM   #5
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice!!
ChuckDriver is offline   Reply With Quote
Old 01-18-2010, 11:18 AM   #6
Houston54
One thing to keep in mind in regards to the tank width is clearance for the pipes if you are planning to run your exhaust out the back. You will need to allow room for the pipes between the tank sides and the rear springs if you are using that type of rear suspension.
Houston54 is offline   Reply With Quote
Old 01-18-2010, 01:58 PM   #7
hotrodrookie
Ya I still havent built my 4 link or mounted my coilovers let alone even purchased them, but the tank is only 8 inches in height, 28.5 wide between the fraimrails and 25 inches in length. Its shorter then the production tanks which are 10 inches tall, so mine shouldnt hang so low. Who knows, Ill probably end up routing my exhaust out the side if I have to.
Old 01-18-2010, 02:57 PM   #8
JML55
JML55's Avatar
Make sure there is enough room in the tank between the baffles for the fuel pump and sending unit. I have a CPP tank and there isn't a center cross baffle so my sender and fuel pump fit nicely in the middle.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 01-18-2010, 08:20 PM   #9
OrrieG
OrrieG's Avatar
I had to modify my float because it interfered with the internal baffles (OLP tank).
Old 01-18-2010, 09:25 PM   #10
hotrodrookie
Well I recently bought a stock internal fuel pump assembly out of a 2002 camaro and im planning on mounting it in there. It has the fuel level sensor built in but I believe the ohm rating is 40 to 240. Any one know if there is a way to convert this to 0-90 or 0-30 ohm gauge?
PS
Could any of you guys who have the productions tanks mease how far down the top of the mounting surface is on the side angle brackets to the top of the fuel tank?
thanks
Old 01-18-2010, 10:56 PM   #11
JML55
JML55's Avatar
3.750" on my fuel tank.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
Old 01-18-2010, 11:52 PM   #12
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
PS
thanks
When you get the programming done on the ECU tell them what year pump you have and they call make that change for you. You don't have to change the sending unit.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 01-19-2010, 09:11 PM   #13
hotrodrookie
So it turns out because I made the tank 2 inched shorter then originally planned(10") the camaro fuel pump wont compress down far enough to fit inside. 10" would have been the perfect hieght. No big deal, I'll probably end up going with the tanks pump now. Anybody need a camaro pump?
Old 01-19-2010, 09:24 PM   #14
texastrendz
hotrod rookie, you can actually shorten those pumps. i did it on my dually project. slide the pump apart, it is two sections. cut the three rods down and shorten the springs and use a flaring tool to flare the tubes back out to hold the springs.
texastrendz is offline   Reply With Quote
Old 01-19-2010, 09:28 PM   #15
hotrodrookie
hmm, interesting. I'll have to look into that then, did you use this same camaro pump or was it a truck one?
Old 01-19-2010, 10:13 PM   #16
texastrendz
it was a truck pump but it looks just like that one pictured. i had to adjust the float level but it works like factory.
Old 01-20-2010, 12:59 PM   #17
Kabwe
Certified Car Nut
Kabwe's Avatar
The tank is looking great. Good job
Kabwe is offline   Reply With Quote
