Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-16-2010, 05:09 PM   #1
LongSixEight
Mini Starter wiring help needed
Im switching to a mini starter on the new motor and Im not sure which starter wire to eliminate to the starter solenoid since the mini only has one terminal. Do I get rid of the wire on the left or right looking at a stock starter from the front of the truck. I had a red on the left and a black on the right. Any help would be appreciated. This is all im lacking to fire up the new motor.
LongSixEight is offline   Reply With Quote
Old 01-16-2010, 05:30 PM   #2
djracer
djracer's Avatar
Re: Mini Starter wiring help needed
I'm not sure what the extra wire is for but the small wire the mini needs is the one that gets hot in the Crank position of the key. It normally has an s on the stock solenoid.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-19-2010, 12:47 AM   #3
LongSixEight
Thanks, Kind of a no-brainer once I thought about it.
Old 01-19-2010, 11:01 AM   #4
cdowns
cdowns's Avatar
if you have an HEI dizzy the yellow wire should have been eliminated when a new hot wire was run to the dizzy///purple wwire goes to the small terminal on mini battery goes to big terminal
