Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 01-17-2010, 02:44 AM   #101
19723DR
19723DR's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
Great job Kevin.
About that last piece, find a large telephone pole and wrap it around till you get the right shape. I know of a guy that made a dash that way.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 01-17-2010, 10:42 AM   #102
Hart_Rod
Hart_Rod's Avatar
Good progress. Keep plugging away.....
Hart_Rod is offline   Reply With Quote
Old 01-17-2010, 12:19 PM   #103
kev2809
low n' slo
kev2809's Avatar
Originally Posted by 19723DR View Post
Great job Kevin.
didnt think of that one. my father in law has some light poles laying in his yard too lol
thanks for the pics!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 01-17-2010, 05:03 PM   #104
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Keep at her she'll be done before ya know it..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-18-2010, 10:58 PM   #105
kev2809
low n' slo
kev2809's Avatar
almost got the patch welded up today. still have some more grinding and welding to do...it actually turned out to be 3 pieces lol
i do have a question though...i think all my doors pop out at the bottom. the gap is perfect up until about where the door handle is...then it start popping out and is kinda bad at the bottom corner. does anyone know why its like that and how to fix them?
-_--_--_ _________
Old 01-18-2010, 11:08 PM   #106
VA72C10
VA72C10
VA72C10's Avatar
could be a weak hinge or just a hinge adjustment/shim needed.
Old 01-18-2010, 11:28 PM   #107
kev2809
low n' slo
kev2809's Avatar
hmm..ima have check on that. im getting ready to fix my rockers in the next week or so i might have to fix that soon
-_--_--_ _________
Old 01-25-2010, 06:54 PM   #108
kev2809
low n' slo
kev2809's Avatar
well i got something done lately. i finished up the area behind the 3rd door...and also made a strip that i welded along the bottom to give it that original pinch weld look.
then i moved on to the driver side to fix the area that needs a wheel arch indention. unfortunately, the blazer piece i bought did not work. the curves are not the same. i didnt figure this out until after i cut out the area on suburban lol. but no biggie, i just welded it back on, and i did use a small piece by the body line that i screwed up the first time i did this (it was first time welding ever when i did that piece)...so it wasnt a total waste of time.
now im still in the hole on how to figure out how to get a body line in there lol. there is no way its gonna stay like that, it will bother me every time i look at it. so we gotta brainstorm here guys...
-_--_--_ _________
Old 01-25-2010, 06:59 PM   #109
kev2809
low n' slo
kev2809's Avatar
today i started on the passenger side rocker. im doing it with the door on right now, and i actually got it off lol. the problem is that i need the part behind the rocker by the fender...so no repairing right now. i followed rokcrln's how to on this...
my backing plate is good so its gonna stay. can someone tell me the name of this part? i want to order it today so i can finish up this rocker by the end of the week!
-_--_--_ _________
Old 01-25-2010, 07:49 PM   #110
mcbassin
Still Learning
mcbassin's Avatar
Although I don't know if a burb is the same as a truck, I think the part you are looking for is #7 front pillar HERE
Old 01-25-2010, 08:43 PM   #111
kev2809
low n' slo
kev2809's Avatar
that looks like it! i wonder though, it looks like half of what i have. is this piece suppose to be cut it in half and welded to the other half? mine looks like i have 4 bolt holes total...
-_--_--_ _________
Old 01-25-2010, 09:24 PM   #112
mcbassin
Still Learning
mcbassin's Avatar
The other half is the fender mount (#5) on the same page at least I think. There are 2- 3/8" bolts that hold it together and it is spotwelded togther.
For your reference Here More is where I changed the same parts on mine.
Old 01-25-2010, 09:36 PM   #113
kev2809
low n' slo
kev2809's Avatar
well...this is what i mean. on yours, it looks like there is enough room on the side to drill the holes for the original bolts, if the new piece didnt have it. on the ones im looking at, it doesnt have any room at all. here is a driver side replacement piece..
doesnt look like any room on the side closest to the door for the 2 original holes.
-_--_--_ _________
Old 01-25-2010, 11:31 PM   #114
my67chevytruck
Under Construction
my67chevytruck's Avatar
hmm weird, i bought mine from lmc and it had enough room to drill the holes...
i just remembered there was not much meat to bite too, i did spot weld and plug weld(not picture) and i did use a bigger washer to bite..
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-25-2010, 11:45 PM   #115
kev2809
low n' slo
kev2809's Avatar
well i guess its not that big of a deal, i can spot weld it in instead of using the screws...i just thought it looked weird. did you replace the back piece too on yours?
-_--_--_ _________
Old 01-25-2010, 11:52 PM   #116
my67chevytruck
Under Construction
yeah i had to patch some of the floor inner kick panel, inner rocker and outer rocker. you can see the first page of the build thread for the carnage...
also i see alot of people plug welding instead of using bolts. I believe kevin even did this on his rocker replacement 101 ( i was skeered to weld that section solid, as i wanted to make sure all lined up first)
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 01-26-2010, 10:34 AM   #117
threeonthetree
threeonthetree's Avatar
great looking build
keep at her!
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 01-26-2010, 11:00 AM   #118
Slick67
Sofa King Crazy!!
Slick67's Avatar
Hey Kevin! Looking good bro! Looks like you are gonna be ready for TexMex, well......in the Under Construction area by me!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 01-26-2010, 01:54 PM   #119
mcbassin
Still Learning
mcbassin's Avatar
Hmmmm? Maybe the burbs are different?
Old 01-26-2010, 07:16 PM   #120
kev2809
low n' slo
kev2809's Avatar
Originally Posted by threeonthetree View Post
great looking build
keep at her!
thanks!
lol. tex mex is creeping up on me way to fast man!
well i thought so too until i seen the ones from ece...
i think i might just order from them...
-_--_--_ _________
Old 01-28-2010, 06:26 PM   #121
kev2809
low n' slo
kev2809's Avatar
and they are on back order lol..i think im gonna order them anyways. there is a few things i can work on while i wait.
im gonna start cutting out the crossmember and getting the frame ready for the notch. question though...i only remove the crossmember in front of the axle right? the one next to the tank stays? i tried sliding it over the frame and it looks like just the front one has to come off. any tips appreciated!
-_--_--_ _________
Old 01-28-2010, 11:19 PM   #122
project 67 sub
project 67 sub's Avatar
you'll most likely have to trim the notch like i did on mine to leave the the rear cross member their, and have the notch centered over the axle.
edit: here's a couple old pics of mine so you can kind of see what I'm talking about
project 67 sub is offline   Reply With Quote
Old 01-29-2010, 11:26 AM   #123
Slick67
Sofa King Crazy!!
Slick67's Avatar
That is a lot of work Kev. Too bad you don't live a little closer I could help you some. Looking good bro, keep it up!
Old 01-31-2010, 12:13 AM   #124
kev2809
low n' slo
kev2809's Avatar
ya i might have to, i finally got mine out but no pics yet. im cleanin up the frame now, getting the bump stop brackets off etc.
lol, its cool. ill get stuff finished one way or another!
look what i picked up today from craigslist...
guy said it was a 78 305 but i havent ran the numbers yet. needs a carb and dizzy (i have a new dizzy). has 35k miles on rebuild
gave me headers and a chrome alternator bracket for free too..
-_--_--_ _________
Old 01-31-2010, 12:26 AM   #125
1sik52
Hey Kev, Sorry that piece behind your driverside wheel didnt work. I have some A pillar patches. Which side do you need and i will send it to you.
1sik52 is offline   Reply With Quote
