Old 01-17-2010, 05:12 PM   #1
64GMCHorsepower
Justified!
Door Mechanism help....
My passenger side outside door handle will not open my door.
When I looked inside the door, the push rod is shorter than the one on the drivers side.
Do they have a different length for different years?
I do not see a way to adjust where the push rod strikes the striker either, so I am thinking I have to buy a new handle........
Anyone else ever had this problem?
1964 GMC Fleetside.......
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 01-18-2010, 02:04 PM   #2
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Re: Door Mechanism help....
I did! I ended up cutting the rods in half and welding them to the correct length. I had purchased new ones for the correct year, but they were long..
I am thinking of ditching the old locks and strikes for a bearclaw..
1962 Chevy P/U SB Fleetside
350/350
2.5/5 static drop
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723
Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441
DaddyMack is offline   Reply With Quote
Old 01-18-2010, 04:48 PM   #3
70 Suburban
Rods
i am gion to try to use 08 chevy plates and handles.I want better handles inside
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 01-18-2010, 05:44 PM   #4
63 & 64 Bowties
and a few others
I know from experience if the handle isn't totally tight against the shell it won't open from the outside. Even a little loose will cause it.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 01-18-2010, 09:48 PM   #5
64GMCHorsepower
Justified!
Well, I have another mechanism to put in the door, so maybe that will work, if not, I am going to try and either replace the rod, or find another handle......
I had 2 or 3 doors, and I am not positive I have the original mechanism or handle on the door......
Stuff gets mixed up over a couple of years.....
Chad
