Old 01-18-2010, 11:02 PM   #1
TLoz
Interior Plastic Repair
I just wanted to share a product that really works. My console for my suburban had numerous cracks. Epoxy wouldn't stick. Found a product called Plasticfix. First I cleaned and cleaned the complete console. Using a dremel, I stop drilled the cracks and vee'd the cracks. I cleaned and cleaned again. I then used the powder in the kit filled the cracks and dripped the activator on the powder. Allowed it to cure and then sanded down. Cleaned and cleaned again. Sprayed adhesion promoter (S.E.M) and then sprayed color. After two coats dried, I sprayed a wet coat and used a paper towel to simulate the console texture. I've heated it up to 120 degrees and worked it and it didn't crack or chip. Got a couple of pics. Let me know if anyone is interested in more details. It took about 3 hrs over 3 days to complete. It was really easy. Later, Tom
TLoz is offline   Reply With Quote
Old 01-19-2010, 12:14 AM   #2
givengold
Re: Interior Plastic Repair
I have the same situation with my console.
Thank you for the tip.
givengold is offline   Reply With Quote
Old 01-19-2010, 10:21 PM   #3
1LowToy
lookin good! Looks like a "Detail Thread" for sure. What kind of paint did you use? I'd love it if my sunburnt door panels could turn out as nice.
1LowToy is offline   Reply With Quote
Old 01-19-2010, 11:19 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
definately interested in details and this will prolly be brought up in the interior forum too.. you may have stumbled onto a good idea there!
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-20-2010, 01:34 AM   #5
ron350
ron350's Avatar
TLoz Where do you buy plasticfix and how much does it cost?
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 01-20-2010, 12:05 PM   #6
Panelman55
Panelman55's Avatar
Will this work to repair a busted 86 dash? I need to fix it on the cheep!!!
In God We trust!!!
Panelman55 is offline   Reply With Quote
Old 01-20-2010, 01:33 PM   #7
hatzie
Moderator
hatzie's Avatar
Is the product you used called Plasticfix or Plastifix?
Plasticfix claims it can do Polyethylene...
Plastifix will NOT work on polyolefin plastics like...
* Polyethylene (PE)
* Polypropylene (PP)
* Thermo Plastic Olefin (TPO)
* Thermo Elastic Olefin (TEO)
Old 01-20-2010, 05:23 PM   #8
old Rusty C10
TLoz this post has been made part of the FAQs for your effort. If youd like to update or write up a more detailed procedure or something please let me know in PM and we can edit that in too.. Thank you on behalf of all of us for your informative thread!!
Bob
I hate cancer!!
Old 01-20-2010, 07:11 PM   #9
Restrorob
The One And Only !!!
Restrorob's Avatar
Looks like it worked pretty well, Can you snap a couple pics just like the first two showing the repaired area in greater detail ?
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-20-2010, 11:25 PM   #10
TLoz
All,Here's some more details:
The adhesive is Plastifix. It will work on ABS. It's available from Urethane Supply Co. It will work on most interior parts, trim and door panels. I haven't tried it on dash pads yet. I used soap and water to clean first, then with NAPA 6385 and 6386. I used these two cleaning items after all operations. I just followed the instructions that came with the kit. It was about $35. I used less than 1/4 of the kit for about 10 cracks. After application and cure, I sanded with 80 grit and then with 400. Clean and clean-this is the most critical part of any composite/glue repair. Next, I used SEM adhesion promoter per the instructions. I used a Sherwin Williams spray bomb paint. I've used this paint on all the interior on this burb and one that I did at least 8 years ago and it hasn't flaked off yet. After a couple of coats, I sprayed a wet oat and used a paper towel to attempt to match the texture. Attached are pics of the final product and detail pics of the repairs. They're not perfect, but good enough for a farm truck.
Old 01-20-2010, 11:31 PM   #11
TLoz
Here's the pictures:
Old 01-21-2010, 12:12 PM   #12
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
Man great info!! thanks for sharing
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 01-21-2010, 01:10 PM   #13
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
If no filling is required, but have cracks that just need "glued" back together, MEK (Methyl Ethyl Keytone) works great....
A quart from Ace Hardware will set ya back $11....
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 01-21-2010, 10:59 PM   #14
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Just be careful with that Ketone stuff- all of the organic volatiles, in fact. Make sure your not huffing it in the closed basement.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
