#101 |
Re: Project 67 DRGNWGN - 67 Burban!!
Great job Kevin.
![]() About that last piece, find a large telephone pole and wrap it around till you get the right shape. I know of a guy that made a dash that way. ![]()
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser 71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished 93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's 98 Chevy short bed DD 97 Z71 3 Door 51 Suburban-S-10 swap "What other hot rod can you carry 7 of your friends in" ![]() |
#102 |
![]() Join Date: Apr 2005
Good progress. Keep plugging away....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#103 | |
low n' slo
![]() Join Date: Mar 2009
thanks for the pics! ![]()
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#104 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Keep at her she'll be done before ya know it..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#105 |
low n' slo
almost got the patch welded up today. still have some more grinding and welding to do...it actually turned out to be 3 pieces lol
![]() i do have a question though...i think all my doors pop out at the bottom. the gap is perfect up until about where the door handle is...then it start popping out and is kinda bad at the bottom corner. does anyone know why its like that and how to fix them?
#106 |
VA72C10
![]() Join Date: Mar 2008
could be a weak hinge or just a hinge adjustment/shim needed.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#107 |
low n' slo
hmm..ima have check on that. im getting ready to fix my rockers in the next week or so i might have to fix that soon
#108 |
low n' slo
well i got something done lately. i finished up the area behind the 3rd door...and also made a strip that i welded along the bottom to give it that original pinch weld look.
![]() then i moved on to the driver side to fix the area that needs a wheel arch indention. unfortunately, the blazer piece i bought did not work. the curves are not the same. i didnt figure this out until after i cut out the area on suburban lol. but no biggie, i just welded it back on, and i did use a small piece by the body line that i screwed up the first time i did this (it was first time welding ever when i did that piece)...so it wasnt a total waste of time. ![]() now im still in the hole on how to figure out how to get a body line in there lol. there is no way its gonna stay like that, it will bother me every time i look at it. so we gotta brainstorm here guys...
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 01-25-2010 at 06:56 PM. |
#109 |
low n' slo
today i started on the passenger side rocker. im doing it with the door on right now, and i actually got it off lol. the problem is that i need the part behind the rocker by the fender...so no repairing right now. i followed rokcrln's how to on this...
![]() ![]() my backing plate is good so its gonna stay. can someone tell me the name of this part? i want to order it today so i can finish up this rocker by the end of the week! ![]()
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 01-25-2010 at 07:00 PM. |
#110 | |
Still Learning
#111 |
low n' slo
that looks like it! i wonder though, it looks like half of what i have. is this piece suppose to be cut it in half and welded to the other half? mine looks like i have 4 bolt holes total...
#112 | |
Still Learning
For your reference Here More is where I changed the same parts on mine.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 01-25-2010 at 09:27 PM. |
#113 |
low n' slo
well...this is what i mean. on yours, it looks like there is enough room on the side to drill the holes for the original bolts, if the new piece didnt have it. on the ones im looking at, it doesnt have any room at all. here is a driver side replacement piece..
![]() doesnt look like any room on the side closest to the door for the 2 original holes.
#114 |
Under Construction
hmm weird, i bought mine from lmc and it had enough room to drill the holes...
i just remembered there was not much meat to bite too, i did spot weld and plug weld(not picture) and i did use a bigger washer to bite..
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 01-25-2010 at 11:39 PM. |
#115 |
low n' slo
well i guess its not that big of a deal, i can spot weld it in instead of using the screws...i just thought it looked weird. did you replace the back piece too on yours?
#116 |
Under Construction
yeah i had to patch some of the floor inner kick panel, inner rocker and outer rocker. you can see the first page of the build thread for the carnage...
also i see alot of people plug welding instead of using bolts. I believe kevin even did this on his rocker replacement 101 ( i was skeered to weld that section solid, as i wanted to make sure all lined up first)
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 01-25-2010 at 11:55 PM. |
#117 |
great looking build
keep at her!
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
#118 |
Sofa King Crazy!!
Hey Kevin! Looking good bro! Looks like you are gonna be ready for TexMex, well......in the Under Construction area by me!!!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() Last edited by Slick67; 01-26-2010 at 11:01 AM. |
#119 |
Still Learning
Hmmmm? Maybe the burbs are different?
#120 | |
low n' slo
thanks!
well i thought so too until i seen the ones from ece... ![]() i think i might just order from them...
#121 |
low n' slo
and they are on back order lol..i think im gonna order them anyways. there is a few things i can work on while i wait.
im gonna start cutting out the crossmember and getting the frame ready for the notch. question though...i only remove the crossmember in front of the axle right? the one next to the tank stays? i tried sliding it over the frame and it looks like just the front one has to come off. any tips appreciated!
#122 |
you'll most likely have to trim the notch like i did on mine to leave the the rear cross member their, and have the notch centered over the axle.
edit: here's a couple old pics of mine so you can kind of see what I'm talking about Last edited by project 67 sub; 01-28-2010 at 11:29 PM. |
#123 |
Sofa King Crazy!!
That is a lot of work Kev. Too bad you don't live a little closer I could help you some. Looking good bro, keep it up!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#124 | ||
low n' slo
look what i picked up today from craigslist... ![]() ![]() guy said it was a 78 305 but i havent ran the numbers yet. needs a carb and dizzy (i have a new dizzy). has 35k miles on rebuild gave me headers and a chrome alternator bracket for free too..
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 01-31-2010 at 12:15 AM. |
#125 |
Hey Kev, Sorry that piece behind your driverside wheel didnt work. I have some A pillar patches. Which side do you need and i will send it to you.
