Old 01-19-2010, 03:07 PM   #1
vtwinsport
vtwinsport's Avatar
Why do I want a higher stall TC?
Hey all,
Why would I want a higher stall torque converter? And, what does that mean "stall".
I know this may obvious to others but I've never had it explained. Considering an upgrade as my tech shop advises a higher stall TC with new cam and heads coming.
Thanks in advance
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 01-19-2010, 03:50 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Why do I want a higher stall TC?
"Stall" is when you smash your foot on the gas, and smash your foot on the brake and note where your engine rpm ends up (like 2500, or 3000 rpm, or whatever).
(...assuming the brakes hold!)
You want a higher stall mostly for racing or brisk street driving, since it will get your engine rpms up into the power band sooner. This would be important if you are going to a cam or intake/carb combination that doesn't like low rpms.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-19-2010, 04:23 PM   #3
joe231
joe231's Avatar
yeah what Keith said.
If you power is up high and you have a factory stall it will be gut-less off the line.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-19-2010, 04:54 PM   #4
dv8customs
dv8customs's Avatar
Detailed explanation from TCI's website
http://www.tciauto.com/Products/Tech..._explained.asp
dv8customs is offline   Reply With Quote
Old 01-19-2010, 05:53 PM   #5
3r!c84
Badass
3r!c84's Avatar
what about just if your going 60 at like 2200 rpm will the converter lock up or will it be slipping becuse its a high stall(i never realy got this??)
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-19-2010, 06:07 PM   #6
68 TT
Still plays with trucks
68 TT's Avatar
If you have a lock up type torque converter it will, if not the trans will be slipping a little at that speed. It will still move just not as efficiently as a lower stall would at the same RPM.
This is where a lock up type converter really works the best. You can have the high stall to get you moving quicker but have the cruise efficiency when it locks up.
Drag racers even use them with multiple lock up clutches to gain top end MPH and eliminate slip. I had a five clutch lock up converter in my 86 Grand National that was built to be locked up at full throttle.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-19-2010, 06:11 PM   #7
78 Chevyrado
If you get a high stall TC make sure to get a big Tranny cooler if you drive it regularly. Slipping= heat It won't hurt it, just make it a lil hotter all the time under the stall speed.
78 Chevyrado is offline   Reply With Quote
Old 01-19-2010, 09:25 PM   #8
68Timber
I know the pieces fit
68Timber's Avatar
Do you know what cam is going in or the specs? I hate to hear that you don't know what you need, the cam will dictate exactly what stall speed you need. You can run up to a Comp 268 which is pretty healthy for a street driven truck with the stock converter. But 68 TT is spot on, if you put any converter in with a higher stall speed you will want to install an aftermarket tranny cooler in front of the radiator. It's not expensive, hard, or time-consuming, but it will dissipate the heat created by a higher stall convertor and keep that tranny running good.
You really need to know the cam specs first to know what convertor you need. The cam might really wake up your truck and turn it into a beast. But with a mismatched converter (too high stall speed) the truck will be a slug and you'll be disappointed.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-19-2010, 09:49 PM   #9
qu1cks1lver56
qu1cks1lver56's Avatar
I've thought about putting a little higher stall converter on my truck just so I'm not fighting it with the brakes at a red light.
qu1cks1lver56 is offline   Reply With Quote
Old 01-19-2010, 10:27 PM   #10
Chlsnk
Chlsnk's Avatar
http://www.starperf.com/index.php?p=...36017&parent=0 This is the cam going in my current engine build (358cid taken .40 over) I was told a 2200-2800 stall would be golden for me. Is this true?
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 01-19-2010, 10:30 PM   #11
78 Chevyrado
A higher stall will cut the need for the "gas pedal two step". I had that in my mustang I used to have and I finally got a consevative 2500 stall and while it wasn't quite a big enough stall for that car, it did cut out playing with the gas at a redlight.
Old 01-19-2010, 10:38 PM   #12
3r!c84
Badass
3r!c84's Avatar
ok how do a lock up converter work?
and will it work with a higher stall tc?
-00 Saturn 5spd
1/4:13:90
Old 01-19-2010, 10:43 PM   #13
qu1cks1lver56
Yeah I have to do that sometimes, gets on my nerves. Some days it seems worse than others, I guess it's the goofy ass FL weather.
Old 01-19-2010, 11:25 PM   #14
78 Chevyrado
a lockup converter will "lock up" at steady cruising speeds like on a highway. It has an actual clutch in the TC.
ALL automatic transmissions slip some at any and every speed, period. What the lockup converters to is make a physical lockup between the trans and engine, like a manual tranny. It's a gas mileage thing. It cut all slip out, but only under low load conditions.
If you ever drove something, say a 4 speed OD tranny, it will actually sound slike a 5 speed at times. You go through all 4 gears, and then the RPMS drop again when the TC locks up. OEM they are electronically controlled, but many aftermarket vendors make 700r4's and 4l60's that have a mechanical lockup, meaning it will work without electronics. I've never driven one with the mechanical setup but the electronis ones work well.
Old 01-19-2010, 11:26 PM   #15
78 Chevyrado
Yeah Luckily i didn't have to drive that thing in stop-n-go traffic much. I'd have done something about it if I would have had to. As much as I had to play with the pedal, I might as well have had a manual and just set the idle to whatever it needed to not stall out.
Old 01-19-2010, 11:27 PM   #16
qu1cks1lver56
and the lockup makes better gas mileage? They make 'em for TH350's?
Old 01-19-2010, 11:44 PM   #17
slugish
Slugish
What is the duration on a 268 cam -- Does it vary from manufactureer to another or is it standard-- the reason Iask Idont knowe what cam Ihave . but Ido know its got 224-230 duration with a 048 lift with 1.5 rockers. Its a comp. cam . My stall is shot , but tranny shifts fine . Iwould like to know what stall converter is best for me or do Ineed any at all . Iknow right now that Ican't get any rpms in my power band without the tires spinning with the shot converter Ihave
slugish is offline   Reply With Quote
Old 01-20-2010, 12:20 AM   #18
78 Chevyrado
I don't think they make any for a TH350. It would either have to have electrical or mechanical provisions inside the trayys to operate.
Old 01-20-2010, 12:21 AM   #19
78 Chevyrado
What size engine?
What tranny?
What rear gear?
what diameter are the tires?
how much does the truck weigh?
Old 01-20-2010, 12:32 AM   #20
qu1cks1lver56
There's never anything cool for a TH350
Old 01-20-2010, 12:55 AM   #21
joe231
joe231's Avatar
there are TH350C transmissions that have lock up converters....
CHEVY ONLY
Old 01-20-2010, 01:11 AM   #22
vtwinsport
vtwinsport's Avatar
Hey guys, thanks for all the input (ha - no pun intended).
Yes, I don't have a budget nor the inclination for a 700r transplant so I'm sticking with the t350.
Bruiser- Truck has stock 350/ t350 with edelbrock carb, intake and headers with 3.08 rear gears (being changed to 3.42 in the spring), dart iron eagle 67 heads coming (now stock 76cc), comp XE 268 cam is in the garage waiting for spring. Stock converter as far as I know in the transmission.
I have the carb and timing tuned as fine as I can (including jets and springs) and I often have to shift into neutral or peddle the gas to keep from stalling at stop llights with current converter.
What I want is more snort from the line- 1000 rpm to 3000 rpm really and I daily drive this with periodic hwy travels in a week. This will never see the strip and there is a factory trans cooler in my rad already. Is that stock one good enough?
Thanks in advance
Old 01-20-2010, 01:37 AM   #23
tonyscustomrides
ya there is lock up torque converters for the th350, my 81 silverado swb has one from factory. the previous owner wired a manual switch to turn it on and it drops the rpms like 200. i go 70 mph rite around 2100 rpms.
77 chevy k10 Bonanza-Restored when i was 17
76 chevy c10 short box-scrapped
81 chevy c10 silverado short box-project
64 impala 2 dr hard top-project waiting to get started
tonyscustomrides is offline   Reply With Quote
Old 01-20-2010, 01:55 AM   #24
qu1cks1lver56
Wonder where to find one.
Old 01-20-2010, 07:48 AM   #25
3r!c84
Badass
3r!c84's Avatar
yours probly has it and you dont even notice ,like mine i dont feel it get into lock up but i can feel it unlock when i floor it at like 60(where it wont down shift) you feel it slip for a sec and then goo!
-00 Saturn 5spd
1/4:13:90
